ebinmaine 80,278 #51 Posted January 3, 2021 1 hour ago, Maxwell-8 said: Except for plowing and snow-removal, Why would you use Tire weights? Would they be good for traction in a mudhole? Trina has a tough time steering on wet or leaf covered ground, not just snow. Her 867 is very light in comparison to my larger tractor and so is she in comparison to my larger me. Hers also has sawtooth tires which have very limited traction. She'll likely leave the front weights on year round. 2 1 Share this post Link to post Share on other sites
slim67 2,825 #53 Posted January 3, 2021 2 hours ago, Maxwell-8 said: Except for plowing and snow-removal, Why would you use Tire weights? Would they be good for traction in a mudhole? Ive gotten buried in soft mud either way but on the front the weights have helped when snowplowing. Rear weights get the power and traction to the ground. 2 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #54 Posted January 3, 2021 36 minutes ago, AMC RULES said: How does it steer? I could see that on an XI with PS but without PS? 1 Share this post Link to post Share on other sites
ebinmaine 80,278 #55 Posted January 3, 2021 10 minutes ago, DennisThornton said: How does it steer? I could see that on an XI with PS but without PS? You just pull/push harder. Good shoulder workout. Share this post Link to post Share on other sites
DennisThornton 4,773 #56 Posted January 3, 2021 7 minutes ago, ebinmaine said: You just pull/push harder. Good shoulder workout. I suppose for intermittent chores it would be a real asset on HARD FLAT surfaces. 1 Share this post Link to post Share on other sites
ebinmaine 80,278 #57 Posted January 3, 2021 3 minutes ago, DennisThornton said: I suppose for intermittent chores it would be a real asset on HARD FLAT surfaces. Definitely agree. I know my Cinnamon Horse gets to be a handful after going in and out of the not smooth forest a lot in one day. Share this post Link to post Share on other sites
briankd 833 #58 Posted January 8, 2021 (edited) On 12/2/2020 at 5:47 PM, WVHillbilly520H said: The 315-8 set up for tilling... i have them same front weights .they won't work on the narrower rims like my 857 the stick out and look dumb .on my c141 they fit perfect with the wider rims i got mine dirt cheap . like to have some original WH weights i know few guys that would sell me some but they like gold want a mint for them Edited January 8, 2021 by briankd 1 1 Share this post Link to post Share on other sites
BeninCT 451 #59 Posted January 13, 2021 On 1/3/2021 at 9:55 AM, DennisThornton said: How does it steer? I could see that on an XI with PS but without PS? Dennis do you have other pics of this setup? Looks like plow frame with an adapter for that small pallet? I like this idea but worry about the lifting lever being able to hold heavier loads. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #60 Posted January 13, 2021 1 hour ago, BeninCT said: Dennis do you have other pics of this setup? Looks like plow frame with an adapter for that small pallet? I like this idea but worry about the lifting lever being able to hold heavier loads. Not mine. Check with AMCRules. 1 Share this post Link to post Share on other sites
ebinmaine 80,278 #61 Posted January 13, 2021 8 hours ago, BeninCT said: heavier loads I wouldn't hesitate a heartbeat to put 200 lbs plus on that. If you can lift it the horse would be fine. @AMC RULES 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #62 Posted January 13, 2021 Just a small engine pallet friction fit, that I slid over the plow frame. Easily picked 300 lbs. but know that I wasn't testing it to failure. Just moving a few items from the garage out back to the shed. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,278 #63 Posted January 13, 2021 53 minutes ago, AMC RULES said: Just a small engine pallet friction fit, that I slid over the plow frame. Easily picked 300 lbs. but know that I wasn't testing it to failure. Just moving a few items from the garage out back to the shed. Back saver. Human energy preservation. Seat time. Great safety procedure. Gott6 tell ya Craig that's an excellent idea. 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #64 Posted January 13, 2021 Keep it simple, works for me. 1 1 Share this post Link to post Share on other sites
BeninCT 451 #65 Posted January 13, 2021 4 hours ago, AMC RULES said: Just a small engine pallet friction fit, that I slid over the plow frame. Easily picked 300 lbs. but know that I wasn't testing it to failure. Just moving a few items from the garage out back to the shed. Must be tough to pull the lift lever to get it off the ground no? Guessing it may be hydraulic now that I look at the pic again... Share this post Link to post Share on other sites
AMC RULES 37,259 #66 Posted January 13, 2021 Yes, gonna have to be a hydro tractor, your're not lifting that by hand unless you're corn fed like Eric. 💪💪 1 Share this post Link to post Share on other sites
ebinmaine 80,278 #67 Posted January 13, 2021 2 minutes ago, AMC RULES said: Yes, gonna have to be a hydro tractor, your're not lifting that by hand unless you're corn fed like Eric. 💪💪 You forget what LITTLE WOMAN does all the lifting around my place don't you Craig.... Share this post Link to post Share on other sites
AMC RULES 37,259 #68 Posted January 13, 2021 Well yeah... the heavy lifting, sure! 1 Share this post Link to post Share on other sites
skippy1969 135 #69 Posted March 6, 2022 On 1/3/2021 at 5:46 AM, Maxwell-8 said: Except for plowing and snow-removal, Why would you use Tire weights? Would they be good for traction in a mudhole? I use them when I mow grass in the summer as well. I mow a very steep side hill and the wheel weights tremendously with stability and traction. 2 Share this post Link to post Share on other sites
