Crmaverick 91 #1 Posted November 30, 2020 So I’m looking to get another plow, I found one off a C series does anyone know if those mount right up to an older round hood like a 753 or 704? I noticed the one on mine the plow frame is V shaped all the way back to the plow mount, but all the ones I see square off and run parallel back to the mount. thanks Share this post Link to post Share on other sites
ebinmaine 77,541 #2 Posted November 30, 2020 20 minutes ago, Crmaverick said: if those mount right up to an older round hood Yepp. Trina's 867 pig pen is a short frame with a long frame plow. 1 Share this post Link to post Share on other sites
Pullstart 68,981 #3 Posted November 30, 2020 Yep, it’ll simply stick out a little further. 1 Share this post Link to post Share on other sites
Crmaverick 91 #4 Posted November 30, 2020 5 minutes ago, pullstart said: Yep, it’ll simply stick out a little further. The rear attach matic fits right up? My rear mount is 16 inches wide the one for sale they told me is 24” wide 2 Share this post Link to post Share on other sites
Pullstart 68,981 #5 Posted November 30, 2020 I can’t see how 24” width would fit between the rear tires? 1 Share this post Link to post Share on other sites
ebinmaine 77,541 #6 Posted November 30, 2020 2 hours ago, Crmaverick said: The rear attach matic fits right up? My rear mount is 16 inches wide the one for sale they told me is 24” wide Can't be for a C series 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #7 Posted November 30, 2020 The V-shaped frames use a rear axle hitch that mounts ahead of the rear axle. The C-Series frames use a rear axle hitch that mounts under the rear axle. The rear axle hitch and frame need to match. The C-Series frames have 2 locations for the rear bar that goes into the hitch to accommodate the long and short frames. Click on the picture in the link. Garry 2 Share this post Link to post Share on other sites
953 nut 64,329 #8 Posted November 30, 2020 8 hours ago, Crmaverick said: the one for sale they told me is 24” wide Either they are measurement challenged or it wasn't on a rear axle bracket. Tell the seller . 1 Share this post Link to post Share on other sites
Crmaverick 91 #9 Posted November 30, 2020 1 hour ago, 953 nut said: Either they are measurement challenged or it wasn't on a rear axle bracket. Tell the seller . what should the width of the rear mount points be on a C series plow, 16”? Share this post Link to post Share on other sites
953 nut 64,329 #10 Posted November 30, 2020 As far as I know they are all 16". I used a lognframe snowplow on my shortframe 1055 for several years and it is now on a 418-C. Share this post Link to post Share on other sites
pfrederi 19,960 #11 Posted November 30, 2020 D series are wider but i do not remember how wide. Too rainy to go out and measure right now... Share this post Link to post Share on other sites
