Mikeahann 0 #1 Posted November 28, 2020 I need help you Share this post Link to post Share on other sites
Mikeahann 0 #2 Posted November 28, 2020 (edited) I’m installing a nova ignition module and directions say to cut wire going to points but this does not work, should I be connecting to the voltage regulator. Directions are for a flywheel coil and K 341 has external coil and voltage regulator which makes me think Install is different Edited November 28, 2020 by Mikeahann Better explanation Share this post Link to post Share on other sites
WHNJ701 4,166 #3 Posted November 28, 2020 I bought one, it never worked no matter how it was hooked up, on a briggs 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,736 #4 Posted November 28, 2020 It is not connected to the regulator. They are for magneto ignitions only and of those only models with a single magnet in the flywheel will work so I'm told. Have never got one to work either. A simple push mower or chainsaw may be the only applications. Garry 1 Share this post Link to post Share on other sites
formariz 12,169 #6 Posted November 30, 2020 On 11/28/2020 at 11:38 AM, Mikeahann said: I’m installing a nova ignition module and directions say to cut wire going to points but this does not work, should I be connecting to the voltage regulator. Directions are for a flywheel coil and K 341 has external coil and voltage regulator which makes me think Install is different The Nova module works only for a self energizing magneto system. You have a battery ignition system. 1 Share this post Link to post Share on other sites
Mikeahann 0 #7 Posted November 30, 2020 I Yeah I found out and went with using a four pin GM module after doing some research supposedly it will work. I greatly appreciate you responding, the seller took all my tractor info and told me it the nova module was compatible after I even told them I read where it not for a battery ignition. Respect brother and have a good day Share this post Link to post Share on other sites
