redone 45 #1 Posted November 25, 2020 Yes, I am searching for one over size piston with rings.0.30 for a 12 hp kohler. Share this post Link to post Share on other sites
pfrederi 19,895 #2 Posted November 25, 2020 Do you mean .030 or .003. .003 was used by Kohler, I understand, when a new engine was just a bit out of spec. .030 is a standard oversized used in rebuilds... Share this post Link to post Share on other sites
Achto 31,017 #3 Posted November 25, 2020 (edited) 1 hour ago, redone said: Yes, I am searching for one over size piston with rings.0.30 for a 12 hp kohler. Here is one source for OEM. http://www.psep.biz/store/kohler_original_equipment_piston_kits.htm You will need to scroll down to find model K301 They also carry aftermarket for the budget minded. http://www.psep.biz/store/kohler_aftermarket_piston_kits.htm If you are in need of the rest of the gasket & seals to install your new piston, you can check the above site for rebuild kits or gasket sets as well. Edited November 25, 2020 by Achto Share this post Link to post Share on other sites
redone 45 #4 Posted November 25, 2020 Thank you for your reference. 1 Share this post Link to post Share on other sites
