JoeM 10,251 #1 Posted November 22, 2020 Got anything you do to make it run better, lets hear it! I do this, inscribe a "witness mark" on rear hubs and axles. A quick look to make sure lines line up will may help to see if hub is coming loose. 4 6 Share this post Link to post Share on other sites
squonk 48,072 #2 Posted November 22, 2020 No pictures but if you have a nasty old mule drive that's all seized up and rusty don't toss it. The frame work can be used for a quick attach front accessory like a weight, sprayer, leaf blower ect. 3 1 Share this post Link to post Share on other sites
Pullstart 71,212 #3 Posted November 22, 2020 When you are tractor heavy, that’s when the best deals come along. 4 Share this post Link to post Share on other sites
c-series don 12,421 #5 Posted November 22, 2020 43 minutes ago, squonk said: No pictures but if you have a nasty old mule drive that's all seized up and rusty don't toss it. The frame work can be used for a quick attach front accessory like a weight, sprayer, leaf blower ect. That’s exactly what I did when I purchased an EZ Rake and restored it. I wasn’t sure how I was going to mount it because the brackets it came with clearly were not for a Wheel Horse. Then the mule drive idea came into play and it works great. I used a lift tube from a snowblower to raise it. I have a pull behind spring tine de-thatcher that I’m thinking about mounting off a mule drive as well. Then I can de-thatch and vacuum up the thatch in one pass. 4 3 2 Share this post Link to post Share on other sites
ebinmaine 80,638 #6 Posted November 22, 2020 Wheel studs and lug nuts. Every tractor we have has them. Every tractor we build will get them. Sooooo much easier to swap tires around or remove for maintenance and repair. 6 1 Share this post Link to post Share on other sites
sqrlgtr 3,860 #7 Posted November 22, 2020 1 hour ago, ebinmaine said: Wheel studs and lug nuts. Every tractor we have has them. Every tractor we build will get them. Sooooo much easier to swap tires around or remove for maintenance and repair. Really makes a difference when you start mounting/dismounting loaded wheels and tires!!!! 2 Share this post Link to post Share on other sites
ebinmaine 80,638 #8 Posted November 22, 2020 33 minutes ago, sqrlgtr said: Really makes a difference when you start mounting/dismounting loaded wheels and tires!!!! Absolutely. My loaded AGs have been on 3 tractors so far and another one soon. 1 Share this post Link to post Share on other sites
squonk 48,072 #9 Posted November 22, 2020 4 hours ago, ebinmaine said: Absolutely. My loaded AGs have been on 3 tractors so far and another one soon. If you have a Harbor Fright () near you get one of those small furniture dollies. You can place the loaded tire/wheel on it and roll it into position and move it around to get the wheel on the studs. That what I do and it beats lifting that loaded wheel up and trying to line up the holes. 4 1 Share this post Link to post Share on other sites
lynnmor 9,037 #10 Posted November 22, 2020 I like the bolts, simply line up one axle hole to one wheel hole and start a bolt. Next, rotate that bolt to the top and the others line up. Never could understand the idea of lining up five bolt holes all at once. 4 Share this post Link to post Share on other sites
ohiofarmer 3,475 #11 Posted November 25, 2020 On 11/22/2020 at 6:38 PM, lynnmor said: I like the bolts, simply line up one axle hole to one wheel hole and start a bolt. Next, rotate that bolt to the top and the others line up. Never could understand the idea of lining up five bolt holes all at once. I like just one stud, then use the bolts. Another tip is to grind off the end of a socket so there is no taper inside the socket. some of the cheaper sockets have so much leade that they can round off the wheel bolts easily. I always use those modified sockets on such things as oil pan drain bolts Share this post Link to post Share on other sites
ohiofarmer 3,475 #12 Posted November 25, 2020 Another good one is to grind down a wrench thin if you have to remove the cap screw off a starter. use the wrench under the cap screw for the supporting stud so it does not break off in the starter housing. Of course you can learn how and why the hard way once you ruin a starter. DAMHIK 1 Share this post Link to post Share on other sites
Chris G 3,392 #13 Posted November 25, 2020 I used a front attach a matic bracket and a old atv rack and made a front rack for my main work machine. The dial on the frant bracket still has the function of leveling the rack, once you put it on. The rack is extremley useful for me. I often strap a 60 pound sand bag on there when im pulling trailers of firewood out. Helps keep the wheelies down on take off. 1 2 Share this post Link to post Share on other sites
pfrederi 21,145 #14 Posted November 25, 2020 12 hours ago, ohiofarmer said: Another good one is to grind down a wrench thin if you have to remove the cap screw off a starter. use the wrench under the cap screw for the supporting stud so it does not break off in the starter housing. Of course you can learn how and why the hard way once you ruin a starter. DAMHIK a pair of tappet wrenches is also a good thing.... 1 Share this post Link to post Share on other sites
Lee1977 7,764 #15 Posted November 25, 2020 On 11/22/2020 at 9:55 AM, squonk said: No pictures but if you have a nasty old mule drive that's all seized up and rusty don't toss it. The frame work can be used for a quick attach front accessory like a weight, sprayer, leaf blower ect. If you don't have an old mule drive all you need is a 5/8" rod and some metal a angle or plate. Here is mine I used a long 5/8" bolt because I had some and an angle to keep it from swing down and hooked below to keep it from swing up. If you are using it for a belt tightener you will want it to swing down. 2 Share this post Link to post Share on other sites
peter lena 10,047 #16 Posted November 25, 2020 joeM , GOOD IDEA , we all have our own tricks and modifications to any trouble issue , depending on what's going on , initially its a quick fix to finish the job , then it gets interesting to make it like it should have been , ( if you want to ) . usually find related areas that can be improved that ,only add to the function to the first problem . my 82 C 85 is the franken horse to experiment and try things on , when proven to be the answer / cure , I typically add it to my other 2 horses . so far its made things very solid and trouble free, pete Share this post Link to post Share on other sites
