Cee245 861 #1 Posted November 20, 2020 (edited) My 417A is now running well after getting new points and condenser installed. First time I've done it and learned a lot of little tricks. It's got the Kt17 series 2 I think. There is no oil filter on it! My question is, what is the rod that comes from the motor called that moves the points open / closed? I'm wondering if there is a seal around it that is prone to leaking? How hard is it to get at? I never noticed before, but there could be what looks like a little oil under the cap of the points. Edited November 20, 2020 by Cee245 Share this post Link to post Share on other sites
Pollack Pete 2,273 #2 Posted November 20, 2020 I'm thinking it's called a points push rod.No seal as far as I know.But......I do think the screw holes on the cover will leak oil if the cover screws are not tight. 1 Share this post Link to post Share on other sites
953 nut 69,558 #3 Posted November 20, 2020 The points are located on the top of your engine and there isn't any pressurized oil up there so it shouldn't be a problem. 1 Share this post Link to post Share on other sites
bds1984 1,519 #4 Posted November 21, 2020 Not all Series II engines have an oil filter. The one in my C175 did not. If you desire to put an oil filter on it, make sure there is a removable block off plate near the rear cylinder, by the PTO side. I bought one from a newer M18 and bolted it right to my Series II and installed an oil filter for a 2015 Ford Focus on it. 2 1 Share this post Link to post Share on other sites
Cee245 861 #5 Posted November 21, 2020 Thanks... Would anyone know what gauge wire goes to the points? Every time I put the cover on, it won't run. There is a little cut in the wire and is shorting out. Share this post Link to post Share on other sites
peter lena 10,076 #6 Posted November 21, 2020 CEE, I would guess in the 14-16 gage , the more important thing is to change the routing of the wire problem . you can also use a small " wire wrap " on ignition wiring to insure its flow , pete Share this post Link to post Share on other sites
c-series don 12,484 #7 Posted November 21, 2020 It’s hard to tell in the picture but it looks like that might be a series one. Share this post Link to post Share on other sites
Cee245 861 #8 Posted November 21, 2020 Here is the plate on the motor... Share this post Link to post Share on other sites
pfrederi 21,184 #9 Posted November 21, 2020 Spec 24300 and up is Series 2 1 Share this post Link to post Share on other sites
