CasualObserver 3,414 #1 Posted May 20, 2009 I found a decent old 40 inch grader blade at auction recently, but it's missing the angled lift link. Would someone please post these measurements of this piece? Share this post Link to post Share on other sites
Duff 206 #2 Posted May 20, 2009 Jason, I've got a mid-mount set-up that looks identical to yours. Mine came with a home-made lift-link made out of a piece of straight bar stock that someone had drilled holes in both ends and merely inserted pins with hairpin clips (is that the right term?) in place of the welded pins in your picture. If this would work for you I can take some measurements tonight for you...... Duff EDIT: There's a pretty good picture of my set-up here: http://www.wheelhorseforum.com/index.php?showtopic=6898 1 Share this post Link to post Share on other sites
CasualObserver 3,414 #3 Posted May 20, 2009 Thanks for that link Duff... I was looking for that one. I hadn't managed to find it yet though... I've been reading many search threads on grader blades....I just got finished re-reading your old thread where you bought that blade. It came out nice, good job! Thanks for the offer... I can probably just give a guess at making a straight flat link... but if someone's got the angled one handy I'd appreciate the measurements. I don't know, but I think there's a functional reason for the length and angle... like maybe better down pressure when grading? It looks like (if installed correctly) that if the blade would try to float or bounce (creating a washboard effect), that link's angle would prevent it from doing so. (just a guess though... ) :omg: Share this post Link to post Share on other sites
Duff 206 #4 Posted May 20, 2009 You are probably right about the down pressure control and floating. I've got some projects ready for the blade but haven't had the time (does that sound familiar to anyone around here?) to hang it on the tractor yet. It WILL happen....I keep telling myself! From reading my old thread, you know I had one helluva time getting the swivel post apart. I hope you don't have to go through that PITA! I'll be watching this thread for the measurements if someone has them, as I may want to fab up an angled link, too. Have a great day! Duff :drool: Share this post Link to post Share on other sites
C-Series14 15 #5 Posted May 20, 2009 I have an angled link, has a number on it...5581 The measurements are: A= 10 1/2" B= 6" C= 4 3/4" pin to pin= 9 3/4" Share this post Link to post Share on other sites
CasualObserver 3,414 #6 Posted May 20, 2009 Thanks Mike. Your link is from the belly section of the two part cultivator. The part number for the grader link is either 5678 or 104357. Anyone know if they're the same size? Share this post Link to post Share on other sites
C-Series14 15 #7 Posted May 20, 2009 I had bought that at the show or somewhere, never really looked into where it went. It works on my C-Series with my 50" grader blade so it must be close. Share this post Link to post Share on other sites
all4glh 0 #8 Posted April 4, 2011 I had bought that at the show or somewhere, never really looked into where it went. It works on my C-Series with my 50" grader blade so it must be close. I know I'll get speared or something for resurrecting an old thread, but pictures in the above posts would be nice to be updated. At least in my case. Share this post Link to post Share on other sites
Brrly1 1,146 #9 Posted April 4, 2011 Jason, I have a picture for you. I actually have both links, 5678 an 104357. I will go ahead and post them. As far as measurements go I think that Mike hit it dead on the head. I hope you know that I read your post an went truckin' out to the garage because I knew I had something close, low an behold, presto. I even had the correct #'s you asked for. So anyways, here ya go. Take care Share this post Link to post Share on other sites
mr.pipes 4 #10 Posted April 4, 2011 It is made from 1/4" plate 1" wide. Pin's from center to center are 9 3/4" Pin's are 1/2" on center from end, 1/16" strong on the small pin Small pin is 3/8" diameter, 5/8" tall Big pin is 3/4" diameter, 7/8" tall with 3/8" diameter X 1/2" pin tacked on 5" from big pin end to center of lever 6" from small pin end to center of lever The angle of offset for the pin's is 2" (if you put one side of lever level to groung, center of one pin is 2" higher than other) Hope that is clear. The 40" is the lower one in the pics, the upper one in the pic is for a 50" Share this post Link to post Share on other sites
all4glh 0 #11 Posted April 5, 2011 So, given what was said here and pictures provided. Does this PDF look fairly accurate? http://www.mediafire.com/?bnxs6s33ociackg Share this post Link to post Share on other sites
all4glh 0 #12 Posted April 12, 2011 Bump if someone could take a look at the document I had posted. Want to get this made this week. Share this post Link to post Share on other sites
mr.pipes 4 #13 Posted April 12, 2011 Bump if someone could take a look at the document I had posted. Want to get this made this week. I tried to look at it before and again just now. No luck. I guess I won a free iphone though. I don't have/use mediafire but have been able to view other peoples pics that they linked to on other file hosting sites. If you can email me a PDF I will check it out. Share this post Link to post Share on other sites
Kelly 1,037 #14 Posted April 12, 2011 Ya I'm not down loading the software to look at a PDF. sorry I got slamed with spam after trying to view it. Share this post Link to post Share on other sites
all4glh 0 #15 Posted April 12, 2011 Not sure what that's about. I can see it just fine with that link. I'll try emailing it. Share this post Link to post Share on other sites
B-8074 20 #16 Posted April 12, 2011 Not sure what that's about. I can see it just fine with that link. I'll try emailing it. I would say it's because you have an account with them. Share this post Link to post Share on other sites
all4glh 0 #17 Posted April 12, 2011 If you could PM me your e-mail I will send it as an attachment. I have it as a PDF. Mr.Pipes, I tried to e-mail you using the board. :thumbs: Share this post Link to post Share on other sites
all4glh 0 #18 Posted April 12, 2011 Let me try using Hotmails SkyDrive. I edited permissions for public to be able to view it, just need to test the link. http://cid-c6b7fa277e190126.office.live.co...easurements.pdf Maybe see if this one works as well. http://dzg2pg.bay.livefilestore.com/y1pD1b...download&psid=1 Both are the same file. Share this post Link to post Share on other sites
all4glh 0 #19 Posted April 19, 2011 Alright, I got the piece made (not by me). I just need to clean it up a little bit, grind down some sharp edges and paint it. I'll have pictures up as soon as I can do that. It's a little over 9.75" from center to center on the pins. I'm going to look it over when I try to install it tomorrow and see if I want to have it cut and welded about an inch or so shorter. I think it's going to be close because there is a 1/4 - 3/8" plate tack welded to the bottom of the grader. Not to mention I want to repaint the blade because it's yellow right now. Share this post Link to post Share on other sites
71_Bronco 1,072 #20 Posted July 20, 2011 Hey Mr Pipes, any chance you could take measurements off the 50" grader blade link? I need to make a link and would apprecieate dimensions. Thanks Share this post Link to post Share on other sites
mr.pipes 4 #21 Posted July 21, 2011 Hey Mr Pipes, any chance you could take measurements off the 50" grader blade link? I need to make a link and would apprecieate dimensions. Thanks The grader is not at my house and I havn't been able to stop and take a look at the link yet. But I will get them for you as I can. Share this post Link to post Share on other sites
mr.pipes 4 #22 Posted July 22, 2011 Hey Mr Pipes, any chance you could take measurements off the 50" grader blade link? I need to make a link and would apprecieate dimensions. Thanks Here is the link to a new post I made with pics and dimensions http://www.wheelhorseforum.com/index.php?act=ST&f=4&t=30084 Good luck and let me know if you have any questions. Share this post Link to post Share on other sites
Woodsman 3 #23 Posted July 22, 2011 This post has perfect timing as I just purchased a 40" blade that needed the lift link. Joe, your PDF file is perfect. I reccomend it goes into the FAQ's. Thank you! Share this post Link to post Share on other sites
squonk 45,589 #24 Posted February 4, 2014 What is the bigger end with the hole used for? Share this post Link to post Share on other sites
