peter lena 9,943 #26 Posted November 17, 2020 yes those 6203 ( 3/4" ) 2rsc3 bearings are the same . ideal size on decks / pto drive , its the grease that does not stand up to hi temp , getting noisy too soon , pete Share this post Link to post Share on other sites
Charbs152 257 #27 Posted November 17, 2020 19 minutes ago, peter lena said: yes those 6203 ( 3/4" ) 2rsc3 bearings are the same . ideal size on decks / pto drive , its the grease that does not stand up to hi temp , getting noisy too soon , pete Awesome, i appreciate the information! Share this post Link to post Share on other sites
JoeM 10,097 #28 Posted November 17, 2020 I use Timken and SKF sealed bearings. I would not get to excited about re-greasing those brands if installed new. Maybe a knock off bearing would have substandard grease. I paid around $5 a piece for the two brands on the bay. Share this post Link to post Share on other sites
Charbs152 257 #29 Posted November 17, 2020 2 minutes ago, JoeM said: I use Timken and SKF sealed bearings. I would not get to excited about re-greasing those brands if installed new. Maybe a knock off bearing would have substandard grease. I paid around $5 a piece for the two brands on the bay. i ended up with a $20 pack of ebay china bearings, i will repack and see how they hold up. i couldnt find the Timkens for less than $10 each 2 Share this post Link to post Share on other sites
JoeM 10,097 #30 Posted November 17, 2020 (edited) Yeah I must have lucked out on those Timken last year. I did get the 10 pack SKF for 45$ this spring. Edited November 17, 2020 by JoeM 1 Share this post Link to post Share on other sites
peter lena 9,943 #31 Posted November 18, 2020 charbs, add this pulley removal to your deck , , scroll down site , near end , just something I came up with , that made sense to me , using mechanical advantage , makes the pulleys pop off , with out damage , pete Share this post Link to post Share on other sites
Charbs152 257 #32 Posted November 18, 2020 (edited) 1 hour ago, peter lena said: charbs, add this pulley removal to your deck , , scroll down site , near end , just something I came up with , that made sense to me , using mechanical advantage , makes the pulleys pop off , with out damage , pete Thanks peter. my pulleys came right off without any issues at all but good info there. I am going to put anti seize on them when i reinstall Edited November 18, 2020 by Charbs152 1 Share this post Link to post Share on other sites
peter lena 9,943 #33 Posted November 18, 2020 charbs , thanks for the feedback, when your deck is finished , this is what I do to stop the rusty grunge , LUBRICATION WILL SAVE YOUR DECK , PETE Share this post Link to post Share on other sites
Charbs152 257 #34 Posted November 18, 2020 (edited) You keep your deck stripped down to bare metal? or is that the stuff youre spraying on it making it look like that? Edited November 18, 2020 by Charbs152 Share this post Link to post Share on other sites
Charbs152 257 #35 Posted November 23, 2020 Update: All deck parts except for the actual deck is primed. There are two small spots i want to try to weld. https://imgur.com/gallery/QjrGzch Share this post Link to post Share on other sites
Charbs152 257 #36 Posted November 23, 2020 (edited) Bought the rubber bumpers Would like to source Roller Stop Spring - 102773 Roller Shaft Assembly - 102770 AS well as a spindle housing for reasonable prices. Edited November 23, 2020 by Charbs152 Share this post Link to post Share on other sites
Charbs152 257 #37 Posted December 1, 2020 (edited) well I took the spindle apart and I have 2 different types. One looks to be original and the other 2 look to be replacements. one has a larger diameter than the other two. I had ordered 6 bearings but the Bearings I ordered only fit the larger shaft. (6203 3/4 2RS/C3) Soo- i ordered up some metric bearings. The paint is coming along nicely also got the decal kit in as well. Still searching for spindle shafts and housings...Anyone got anything? Edited December 1, 2020 by Charbs152 Share this post Link to post Share on other sites
