kawimaniac2145 6 #1 Posted November 14, 2020 hey guys. what would i need to do to hookup a plow to my 520-h any helps appreciated thanks. Share this post Link to post Share on other sites
peter lena 9,609 #2 Posted November 14, 2020 newbie, you can get familiar with these pictures,https://www.google.com/search?sxsrf=ALeKk01c6RyxAtkGS-dCYxFr0Kt9mC_sCA:1605377497214&source=univ&tbm=isch&q=wheel+horse+rear+plow+frame+mount&sa=X&ved=2ahUKEwjGos6b0YLtAhUuxVkKHavfCLUQjJkEegQIBhAB&biw=1024&bih=625, if you have a plow , like a 42" -48" -or a 54" on the frame you also need the ( rear axel hook up frame ),which lets you easily support the rear of the plow frame , also put 1/8" R type safety clips into the swing arm holes , to secure the frame. look over the various mounting pictures , for ideas and insight . really a simple hook up, take the time to detail lubricate all movement points , I get mine ready on 2 milk crates , letting me verify its swing and movement areas , if you get it built and its smooth and easy , that how it will be on your 520. lubrication is key , pete Share this post Link to post Share on other sites
peter lena 9,609 #3 Posted November 14, 2020 newbie, a picture is worth a thousand words , https://www.google.com/search?sxsrf=ALeKk01c6RyxAtkGS-dCYxFr0Kt9mC_sCA:1605377497214&source=univ&tbm=isch&q=wheel+horse+rear+plow+frame+mount&sa=X&ved=2ahUKEwjGos6b0YLtAhUuxVkKHavfCLUQjJkEegQIBhAB&biw=1024&bih=625 , this will also help , pete Share this post Link to post Share on other sites
peter lena 9,609 #4 Posted November 14, 2020 go to snow plow install, pete Share this post Link to post Share on other sites
kawimaniac2145 6 #5 Posted November 14, 2020 ok will try all that. someone also said that i need an extension? Share this post Link to post Share on other sites
peter lena 9,609 #6 Posted November 14, 2020 frame ext picture on this site, pete Share this post Link to post Share on other sites
lynnmor 8,307 #7 Posted November 14, 2020 1 hour ago, kawimaniac2145 said: ok will try all that. someone also said that i need an extension? To mount a snow plow not made exclusively for the 520, you need an extension. manual Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #8 Posted November 14, 2020 It it the shiny red parts added to the A frame... Unless you have an '88 or '89 straight axle 520... 90-97 has the swept forward front axle requiring the extension kit... Here's a brief pictorial of hitching up the snow plow using the "floating" lift link. Also my home brew front anti-sway bar, and the correct angle from seat lever. The extension kit can be procured from here... https://www.wheelhorsepartsandmore.com/brackets-linkages.html#!/Toro-Wheel-Horse-520-Snow-Plow-EXT-Kit/p/84954631/category=23566571. 2 Share this post Link to post Share on other sites
rjg854 12,695 #9 Posted November 15, 2020 @kawimaniac2145 Share this post Link to post Share on other sites
953 nut 63,386 #10 Posted November 15, 2020 18 hours ago, kawimaniac2145 said: hey guys. what would i need to do to hookup a plow to my 520-h any helps appreciated thanks. If you are in need of parts and pieces to make this work we have a classified section here, it is free. https://www.wheelhorseforum.com/classifieds/wanted/?do=form&d=2 Share this post Link to post Share on other sites
