Lane Ranger 12,167 #1 Posted November 13, 2020 This has probably been discussed or posted before on Red Square but I was going through RJ and Suburban transmission parts boxes today for someone and came across two #3525 Cluster Gears. Interesting to note that from the 1958 RJ three piece transmission thru 1974 B-80 Wheel Horse tractor transmissions ( and I am sure later models also) that the cluster gear is the same! the only change appears to be a one half inch longer center shaft on the #3525 Cluster Gear for the later two piece transmissions versus the three piece ones. 6 Share this post Link to post Share on other sites
Dnorth 7 #2 Posted February 25 (edited) Do you still have these gears? I have what I believe is a 5060 6 speed (1,2,3,R, H,L). My cluster gear has some broken teeth. according to the a old parts diagram I need part number 3525. If you still have these, could I purchase one from you? If not, could you point me in the right direction? I cant find any on ebay. Edited February 25 by Dnorth Share this post Link to post Share on other sites
peter lena 10,121 #3 Posted February 26 @Dnorth often refer to , FLUSHING OUT A GEAR BOX ? have found hi milage ATF fluid drive around , put some miles and time on that cleaning ability , use every gear / range , you want to see a color debris effect ? also drain out with front end jack stand support for best drainage , like a climbing gear oil , read specs , also tye wrap just ABOVE new shift boot ? on shaft , find where it wants to be , then hold it there , also like to to lightly grease the UNDERSIDE OF BOOT ? ENHANCES , movement slide over iregularites , helps it stay in place . all of my trans oils are clean / clear , have a regular look see for anything , then kill it . pete Share this post Link to post Share on other sites
