Lane Ranger 11,705 #1 Posted November 13, 2020 This has probably been discussed or posted before on Red Square but I was going through RJ and Suburban transmission parts boxes today for someone and came across two #3525 Cluster Gears. Interesting to note that from the 1958 RJ three piece transmission thru 1974 B-80 Wheel Horse tractor transmissions ( and I am sure later models also) that the cluster gear is the same! the only change appears to be a one half inch longer center shaft on the #3525 Cluster Gear for the later two piece transmissions versus the three piece ones. 6 Share this post Link to post Share on other sites
