Tony in Australia 2 15 #1 Posted November 10, 2020 Hi there team. Just bought my next W/H 416-8 with an Owan twin. I have a few questions I would like some advice on please. 1. The Throttle lever will not stay in the open high speed position, ie; in the all the way up, how do you adjust it, the manual gives on guidance. 2. Do you run the Owan flat out- full speed when operating the cutting deck. 3. Can anyone explain the relationship between the throttle position and how the governor work please, I know what a governor does and how it works but in conjuction with throttle position, not sure. Thanks in advance TC Australia 1 Share this post Link to post Share on other sites
lynnmor 8,083 #2 Posted November 10, 2020 1. The throttle lever has a pivot point, most likely a rivet, put a small high strength screw thru there and use a lock nut. Squeeze the rivet till it holds the lever firmly. 2. Yes. 3. There is a throttle stop tab that you adjust by bending to get the maximum 3600 RPM. The idle speed is adjusted by a screw on the governor, you first adjust the low idle speed on the carburetor and then you adjust the governed idle speed a little bit higher. The instructions are in the Onan Service Manual available on this site. Share this post Link to post Share on other sites
Tony in Australia 4 #3 Posted November 10, 2020 Thanks so much Lynnmor for the very quick response and the good advice. The hour meter has only 182hr total so I will fix the pivot and see how that goes before I mess with the carby. Thanks again 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #4 Posted November 11, 2020 182 hrs! Lucky you! 1 Share this post Link to post Share on other sites
Pullstart 68,180 #5 Posted November 11, 2020 we love pictures! 1 Share this post Link to post Share on other sites
