Marv 981 #1 Posted November 10, 2020 I am overhauling my 48" deck and need a center pulley. The part number is 106073. The center bore is 3/4 with a keyway. Anybody have one Marv Share this post Link to post Share on other sites
peter lena 9,279 #2 Posted November 10, 2020 MARV, I don't have a pulley , but I do have advise on your grease , at every opportunity , use a hi temp grease , like lucas RED n tacky , having done a number of decks , the failure is typically due to a low temp / generic grease . since detailing my hi temp grease , there is very quiet and smooth operation. those 6203 rubber bearing seals are easily , removed with a pocket screwdriver , swipe out the existing lube , and hand pack hi temp grease , seals go right back in place. I even did my 6203 PTO Bearings, same thing . this might put off the purists , but if you can stop a failure while rebuilding , why not do it ? hi temp grease has a typical 550 flash point , and it will stay with your deck bearings . also detail your build , eliminate issues . those decks can run quietly , pete 1 Share this post Link to post Share on other sites
peter lena 9,279 #3 Posted November 10, 2020 MARV , pictures of pry bar pulley removal , this what I do , 1 Share this post Link to post Share on other sites
Marv 981 #4 Posted November 18, 2020 On 11/10/2020 at 10:28 AM, peter lena said: MARV, I don't have a pulley , but I do have advise on your grease , at every opportunity , use a hi temp grease , like lucas RED n tacky , having done a number of decks , the failure is typically due to a low temp / generic grease . since detailing my hi temp grease , there is very quiet and smooth operation. those 6203 rubber bearing seals are easily , removed with a pocket screwdriver , swipe out the existing lube , and hand pack hi temp grease , seals go right back in place. I even did my 6203 PTO Bearings, same thing . this might put off the purists , but if you can stop a failure while rebuilding , why not do it ? hi temp grease has a typical 550 flash point , and it will stay with your deck bearings . also detail your build , eliminate issues . those decks can run quietly , pete Pete, Thanks for your reply. interesting information. Marv 1 Share this post Link to post Share on other sites
KREP 15 #5 Posted December 5, 2020 I’ve got 3 spindle pulleys brand new. They didn’t fit my deck so I swapped them with the originals from my old deck. Tell me the diameter and I’ll send along if they’re the same. Share this post Link to post Share on other sites
KREP 15 #6 Posted December 6, 2020 Pulley diameter at edges. I think shafts are all the same. 1 Share this post Link to post Share on other sites
Charbs152 254 #7 Posted December 8, 2020 On 12/5/2020 at 3:08 PM, KREP said: I’ve got 3 spindle pulleys brand new. They didn’t fit my deck so I swapped them with the originals from my old deck. Tell me the diameter and I’ll send along if they’re the same. 3/4 or 5/8 shaft? Share this post Link to post Share on other sites
KREP 15 #8 Posted December 11, 2020 5/8 shaft. The pulley has a small hole with splines around the opening to fit over the shaft. The shaft diameter itself is 5/8. Share this post Link to post Share on other sites
KREP 15 #9 Posted December 26, 2020 Nope, 5/8 and 3/4 don’t fit. I miked them. The shaft is .665 so the bearing is a 6203. With a 17 mm ID. Share this post Link to post Share on other sites
