Retired Wrencher 6,020 #1 Posted May 20, 2009 <_< how would hook up an volt meter to a 12 volt systeam. Is by the wire harness or outher t/y from T1257 Share this post Link to post Share on other sites
WheelHorse_of_course 100 #2 Posted May 20, 2009 To be safe it should be fused. And to prevent the voltmeter form draining the battery, it needs to be connected to a place that has power only when the ignition is on. So..... Connect the (-) to ground Connect the (+) to the fuse block (any fused circuit that gets cut off when the ignition is off would be fine). Make sure to connect it to the fused side of the fuse box. If you are uncertain which side is fused , remove the fuse. The side that is still live is the unfused side, so your (+) wire should go to the other side. How to interpret your volt meter With the engine running above a fast idle, you should see just under 14 volts. When you turn the engine off the voltage should drop to about 12.4 volts. If you let it sit over night voltage should be between 11-12 volts before starting. If the above are not true, take a look at your amp meter. If it does not show current, then your problem is the charging system . If it does show current, then you either need to run it for a while to charge the battery, or the battery needs to be replaced. :drool: Share this post Link to post Share on other sites
Retired Wrencher 6,020 #3 Posted May 20, 2009 To be safe it should be fused. And to prevent the voltmeter form draining the battery it needs to be connected to a place that has power only when the ignition is on. So..... Connect the (-) to ground Connect the (+) to the fuse block (any fused circuit that gets cut off when the ignition is off would be fine). Make sure to connect it to the fused side of the fuse box. If you are uncertain which side is fused , remove the fuse. The side that is still live is the unfused side, so your (+) wire should go to the other side. How to interpret you volt meter With the engine running you should see just under 14 volts. When you turn the engine off the voltage should drop to about 12.4 volts. If you let it sit over night voltage should be between 11-12 volts. If the above are not true, take a look at you ampmeter. If it does not show current then your problem is the charging system . If it does show current then you eother need to run it for a while to charge the battery, or the battery needs to be replaced. t/y wheelhorse but this is a 1978/79 c141 and I have it all apart I did not notice any fuse block. Just straight wiring, to where it was needid. it sounds like by ur e-mail I can runit of the key or in my case the push button starter. t/c Gary B........................ Share this post Link to post Share on other sites
WheelHorse_of_course 100 #4 Posted May 21, 2009 BTW T, Does it have lights? If so it should have an inline fuse in the dashboard space under the hood behind the dashboard. If not, I would advise you pick up an in-line fuse holder! Don't want to risk a burning horse. If you post the model code number off the tag on the side there is a good chance someone on this board will post a wiring diagram. My Charger had no guages, though you can see from my sig. that is no longer the case. Good luck, have fun... :drool: Share this post Link to post Share on other sites
Retired Wrencher 6,020 #5 Posted May 21, 2009 BTW T, Does it have lights? If so it should have an inline fuse in the dashboard space under the hood behind the dashboard. If not, I would advise you pick up an in-line fuse holder! Don't want to risk a burning horse. If you post the model code number off the tag on the side there is a good chance someone on this board will post a wiring diagram. My Charger had no guages, though you can see from my sig. that is no longer the case. Good luck, have fun... T/u wheelhorse. no there are no head lights that in use. there are but some one cut the wires at the bulbs. and the switch that turend them on/off is used for a kill switch. This is the way I bought it. alittle hack`t up but every thing worked before I tore it down. if I could get a wiring diagram this would help. the only plate that I found was on the side,it said I.D.#`s 81-14ks01-094738060 I hope this did help u. Thanks again. Gary B............... Share this post Link to post Share on other sites
