Tom kite 3 #1 Posted November 8, 2020 starter making funny sound how can I check the starter. Share this post Link to post Share on other sites
lynnmor 8,083 #2 Posted November 8, 2020 (edited) Check the two mounting bolts to see if they are tight. If that isn't the problem, remove those bolts and wiring to remove the starter. Put some light oil on the starter drive to free it up, then connect the wires and run it. Rotate the engine and look for bad teeth on the flywheel. If you still have noise you can use the Onan Service Manual, available on this site, for disassembly information. Since parts may be a problem, look for a good used starter, don't buy the cheap junk available at many places. Edited November 8, 2020 by lynnmor Share this post Link to post Share on other sites
