Searcher60 209 #1 Posted November 8, 2020 (edited) Anybody know of a oil seal cross reference chart for the K301 Kohler? Purchased a gasket set from Amazon, oil seals do not fit. PTO side crankshaft seal is to small in diameter. Bearing plate side may be to large, but mite work if forced. Thanks a bunch. Edited November 8, 2020 by Searcher60 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #2 Posted November 8, 2020 What is the spec number? Garry Share this post Link to post Share on other sites
seven 202 #3 Posted November 8, 2020 Talk to your local kohler dealer Share this post Link to post Share on other sites
Searcher60 209 #4 Posted November 8, 2020 3 hours ago, gwest_ca said: What is the spec number? Garry 47147, Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #5 Posted November 8, 2020 Kohler part numbers https://www.partstree.com/models/k301-47147-kohler-k-series-engine-made-for-wheel-horse-12hp-9kw/crankcase-02110071138-14/ Pto seal size at a Stens dealer https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=1563 Front seal size at a Stens dealer https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=1562 Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #6 Posted November 8, 2020 I did look to see if SKF recognized the Kohler seal numbers but they do not. Second best was Stens show the seal dimensions. Napa carries the Prime-Line products which are like Stens. Rotary is another. This Toro distributor also carries the Stens line. Search for a Kohler item and both will come up if available https://www.rcpw.com/search/?quest=4703207 https://www.rcpw.com/search/?quest=4703206 Last one no Stens replacement shown. Banta Saw is in Ontario Canada This dealer has reasonable prices and I understand a flat rate shipping charge. Good time to build an order if other parts needed. http://www.psep.biz/index.htm Go to the bottom of the page and use the OM parts or https://www.psep1.biz/arinet.asp#/s/KOH//47_032_06/1/ https://www.psep1.biz/arinet.asp#/s/KOH//47_032_07/1/ Garry Share this post Link to post Share on other sites
Searcher60 209 #7 Posted November 9, 2020 The Stens 495-630 PTO side crankshaft seal I received today from Amazon fits perfect. I talked to Stens this morning and they no longer supply the crankshaft bearing plate seal, 495-622. So, I am going to see my Kohler rep for a $15 oem. I will then have the correct seal number. Maybe. Share this post Link to post Share on other sites
tom2p 2,394 #8 Posted November 10, 2020 On 11/7/2020 at 8:56 PM, seven said: Talk to your local kohler dealer local Kohler dealer ? Share this post Link to post Share on other sites
