jeremi3210 742 #1 Posted November 5, 2020 Anyone ever try to drill and tap a oil pan from a wide block Kohler to fit it on a wheelhorse frame? I've got a few wide pans laying around that don't have the holes in the bottom been thing of giving it a try. 1 Share this post Link to post Share on other sites
Pullstart 68,180 #2 Posted November 5, 2020 Congrats on your supporter status Jeremi! Can’t wait to see the progress on “Steve” the puller! I recall from my tool and die days that threads in cast iron need to be 2x the diameter of thread. For 3/8” bolt mounting, do you have 3/4” of meat to tap? 1 Share this post Link to post Share on other sites
pfrederi 18,970 #3 Posted November 5, 2020 Use "J" bolts 1 Share this post Link to post Share on other sites
jeremi3210 742 #4 Posted November 5, 2020 37 minutes ago, pullstart said: Congrats on your supporter status Jeremi! Can’t wait to see the progress on “Steve” the puller! I recall from my tool and die days that threads in cast iron need to be 2x the diameter of thread. For 3/8” bolt mounting, do you have 3/4” of meat to tap? Thanks finally bit the bullet and did it!!! Definitely will do a post on Steve when the time comes, right now Jacob is still in plowing mode and wants to build his 953. On the pan iam not sure but I doubt if Kohler made specific ones just for wheelhorse. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #5 Posted November 5, 2020 45 minutes ago, jeremi3210 said: Thanks finally bit the bullet and did it!!! Definitely will do a post on Steve when the time comes, right now Jacob is still in plowing mode and wants to build his 953. On the pan iam not sure but I doubt if Kohler made specific ones just for wheelhorse. I have done it twice. It is doable. Bolt one side to the frame and mark the holes out on the other side. Dont go too deep. 1 1 Share this post Link to post Share on other sites
