Marvin Moore 1 #1 Posted November 3, 2020 (edited) Hello new to the forum, new to Wheelhorse love it , question what weight oil are you guys using in these kohlers, and what about the transmission is 10w30 fine. Thanks Dwight Edited November 3, 2020 by Marvin Moore 1 Share this post Link to post Share on other sites
Bill D 2,508 #2 Posted November 3, 2020 10w-30 synthetic in the trans. 30w in the engine. Look for SJ rated engine oil for proper zinc content. Bill Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,921 #3 Posted November 3, 2020 Welcome to the forum Click on the fuzzy pictures Garry Share this post Link to post Share on other sites
The Tuul Crib 7,340 #4 Posted November 3, 2020 T😎 Check the color of your trans fluid If its amber then use 10w30 lf its red then go with trans fluid . Dont mix the two. Napa has Dex Merc trans fluid and for motor oil l use Shell Rotella T1 30 w Share this post Link to post Share on other sites
953 nut 63,577 #5 Posted November 3, 2020 While servicing the transmission you will want to replace the filter also. A NAPA 1410 or Wix 51410 filter will do the trick. Share this post Link to post Share on other sites
Marvin Moore 1 #6 Posted November 4, 2020 Thanks everyone for the replies, just got away from a 300 series JD that has a sealed non serviceable trans,,that went out at 300 hrs now I have something to work with , unit has 500 hrs should last a pretty while. Thanks again. Marvin Share this post Link to post Share on other sites
