whtractors24 3,443 #1 Posted November 2, 2020 (edited) My 97 520-H gauge seems to read right when you turn key on but when it’s running it full throttle the gauge reads 16 volts or so . I checked the battery at full throttle with my volt meter and read 14.3 . Do you believe this is a faulty gauge ? Edited November 2, 2020 by whtractors24 Share this post Link to post Share on other sites
lynnmor 8,254 #2 Posted November 2, 2020 The gauge may be reading too high, check the voltages with both meters with the engine at idle and with the engine off. If the voltages match with the idle and off tests, the voltage regulator may be leaking some AC that only one meter picks up. Share this post Link to post Share on other sites
953 nut 63,002 #3 Posted November 2, 2020 If your R/R doesn't have a good ground the voltage output can be high. 1 Share this post Link to post Share on other sites
whtractors24 3,443 #4 Posted November 2, 2020 It does Match up I tested that. Maybe try my other regulator . Share this post Link to post Share on other sites
whtractors24 3,443 #5 Posted November 2, 2020 1 minute ago, 953 nut said: If your R/R doesn't have a good ground the voltage output can be high. What is r/r ? Share this post Link to post Share on other sites
whtractors24 3,443 #6 Posted November 2, 2020 1 hour ago, lynnmor said: The gauge may be reading too high, check the voltages with both meters with the engine at idle and with the engine off. If the voltages match with the idle and off tests, the voltage regulator may be leaking some AC that only one meter picks up. Thought if it’s putting out to much ac that would make high dc power. At full throttle on my Digital amp meter I’m at 14.3 and tractor gauge is up near 16 . Share this post Link to post Share on other sites
lynnmor 8,254 #7 Posted November 2, 2020 14 minutes ago, whtractors24 said: Thought if it’s putting out to much ac that would make high dc power. At full throttle on my Digital amp meter I’m at 14.3 and tractor gauge is up near 16 . No, you have a voltage regulator to do just that. R/R mentioned above means regulator/rectifier. Did you do the tests I mentioned? I hope you are using a voltmeter not an ammeter. 1 Share this post Link to post Share on other sites
whtractors24 3,443 #8 Posted November 3, 2020 50 minutes ago, lynnmor said: No, you have a voltage regulator to do just that. R/R mentioned above means regulator/rectifier. Did you do the tests I mentioned? I hope you are using a voltmeter not an ammeter. Yes I did use a volt meter and on it was 14.3 at full throttle but the gauge on the tractor was higher than what volt meter tested at Share this post Link to post Share on other sites
stevebo-(Moderator) 8,600 #9 Posted November 3, 2020 Someone mentioned check ground. Share this post Link to post Share on other sites
lynnmor 8,254 #10 Posted November 3, 2020 Someone mentioned checking voltage at idle and with the engine off, that didn't happen. Share this post Link to post Share on other sites
whtractors24 3,443 #11 Posted November 3, 2020 11 minutes ago, lynnmor said: Someone mentioned checking voltage at idle and with the engine off, that didn't happen. I did engine off 12.6 idle 13.2 -13.4 Share this post Link to post Share on other sites
lynnmor 8,254 #12 Posted November 3, 2020 1 minute ago, whtractors24 said: I did engine off 12.6 idle 13.2 -13.4 Did that match the tractor gauge? Share this post Link to post Share on other sites
whtractors24 3,443 #13 Posted November 3, 2020 42 minutes ago, stevebo said: Someone mentioned check ground. Steve I checked ground even ran a jumper ground to regulator still same . I checked voltage behind the gauge while off / running it’s same as battery . However when the machine is off if I’m at 12.6 on my volt meter the gauge on the tractor seems to be reading a tad higher . I’m starting to think it’s a faulty gauge . I will swap the one from my other 520 here today to determine if it’s the gauge . 2 Share this post Link to post Share on other sites
whtractors24 3,443 #14 Posted November 3, 2020 11 minutes ago, lynnmor said: Did that match the tractor gauge? Not 100% accurate no . I also compared it to my 91 520 that the tractor gauge is working properly . The 97 seems to be bit high . Share this post Link to post Share on other sites
whtractors24 3,443 #15 Posted November 3, 2020 9 hours ago, lynnmor said: Did that match the tractor gauge? Ok determined it is in fact a faulty tractor gauge ! 1 Share this post Link to post Share on other sites
