Consigliere 11 #1 Posted November 2, 2020 I am looking at a 6-6211 snowblower attachment for sale which was apparently the model number for The Raiders, Chargers, and the GT-14 for the 1969 model year. Does anyone know if this will fit a 1976 B-80? Please let me know. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #2 Posted November 2, 2020 Welcome to the forum. Back in the day that snowthrower came in two packages. The 6-6211 was the basic unit and the second package provided what was needed to attach to certain models of tractor. The Chargers and Raiders required the 6-9111, 6-9112 or 6-9113 kit for the long frame models. I believe the 1976 B-80 is a long frame tractor and has a front quick hitch. The 6-6211 may still mount using a long bolt and two bushings through the front of the tractor frame. Hopefully some one will chime in to verify this is correct. https://www.wheelhorseforum.com/search/?q=6-6211&quick=1&type=downloads_file Here is a list of all on them for the long frame tractors Snowthrower DNA All have 2 idler sprockets for the drive chain. Started out as 37" wide and the added wings make them 42" wide. 1966-67 model ST-376 1968 model 6-1211 1969 6-6211 plus 6-9111 1970-72 model 6-6212 plus 6-9112 All without front quick hitch so not a direct fit for 1973 and later tractors. Snowthrower rear frame mounts in the front of the tractor frame using 2 bushings and a long 3/8-16 x 8-1/2" bolt. ------------------------------------------------------------------------------------------------------------ Front quick hitch introduced. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) 1976 model 6-6215 - This one - 1976 model 66-42ST01 - and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - This one 1978 model 86-42ST01 - and this one 1979 model 96-42ST01 - and this one plus 1980 may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) 2002-2007 model 79362 Garry Share this post Link to post Share on other sites
Ed Kennell 45,039 #3 Posted November 2, 2020 I think there were three mounting kits for these blowers. One used the front guick hitch, one used the long bolt and bushings thru the two holes in the frame. Either of these should work on your B-80. The third mounting kit was for a GT and I am not sure how it differed from the other two kits. Share this post Link to post Share on other sites
