Bill D 2,510 #1 Posted October 28, 2020 I have an M16 with what I believe is a balance gear rattle. Can I remove the balance gears and have it run without excessive vibration? I know this is doable on the K series, but have seen mixed opinions on doing this on the M series. Thanks. 2 Share this post Link to post Share on other sites
johnnymag3 2,634 #2 Posted October 28, 2020 Don't know for sure..... The M guys will chime in with the info you need Im sure Share this post Link to post Share on other sites
pfrederi 19,501 #3 Posted October 28, 2020 The only differences between an M-16 and K-341 Ignition system, engine shroud and exhaust elbow. Share this post Link to post Share on other sites
bds1984 1,506 #4 Posted October 30, 2020 I really didn't notice any increase in vibration in the K341 on my C165. That engine has a shaker plate engine mount so I couldn't tell beyond the norm from that. The gears were pulled based upon the recommendation of many people here who've made the same move on their engines. It is worth a look at them to inspect how they are. I've seen those gears let loose and take out a perfectly running engine. Share this post Link to post Share on other sites
The Tuul Crib 7,340 #5 Posted October 31, 2020 I took my balance gears out of the last two motors I had appart and really can't notice a whole lot of difference. Take them out and leave them out! Share this post Link to post Share on other sites
Bill D 2,510 #6 Posted October 31, 2020 1 hour ago, The Tuul Crib said: I took my balance gears out of the last two motors I had appart and really can't notice a whole lot of difference. Take them out and leave them out! Were those K series or M series engines? I keep seeing articles about, mainly on the Brian Miller website, that says they can't be removed on an M series engine. Share this post Link to post Share on other sites
The Tuul Crib 7,340 #7 Posted October 31, 2020 46 minutes ago, Bill D said: Were those K series or M series engines? I keep seeing articles about, mainly on the Brian Miller website, that says they can't be removed on an M series engine. They were both k motors . I've been inside of both K and M series and they are almost identical. The crankshaft is already balanced so taking out the isn't taking much of that away. There might be just a little more vibration but it's nothing overpowering. My opinion it's vibration therapy! Share this post Link to post Share on other sites
pfrederi 19,501 #8 Posted October 31, 2020 51 minutes ago, Bill D said: Were those K series or M series engines? I keep seeing articles about, mainly on the Brian Miller website, that says they can't be removed on an M series engine. Are they concern bout the Mahle Pistons??? Interesting the part number for eh balance gears themselves are eh same between K 341 and Magnum 16.... Share this post Link to post Share on other sites
richmondred01 2,323 #9 Posted November 1, 2020 Yes Prfrederi I believe the concern is the Mahle piston in the m16 and the way it’s balanced. However, I remove them on all my rebuilds anyway. Unless the customer wants the balance gears back in on the m16 only. If so, I press new bearings into the gears, mic the pins and gauge the play with feeler gauge. Even after all that, I won’t guarantee the engine with them installed. All my personally owned k and m engines the balance gears have been removed with no issues. Share this post Link to post Share on other sites
