bo dawg 518 #1 Posted October 26, 2020 This is the Ark 508 loader I aquired couple weeks ago. Is this the way they all bolt up to the sub frame? Seems weak to me, plus looks like PO had to do some welding. But looks to have bend the frame a little. Its been worked hard Im sure but what has other guys done to improve this? The oil drain is on the bottom of this side as well. Share this post Link to post Share on other sites
Goldnboy 1,035 #2 Posted October 26, 2020 I would add a small section of the same diameter and gauge tubing an weld or bolt to subframe for added strength since this is already a weak spot. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #3 Posted October 26, 2020 Arc 700. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #4 Posted October 26, 2020 Take the guess work out of bucket levelling. 1 Share this post Link to post Share on other sites
Lee1977 7,215 #5 Posted October 26, 2020 A bad design of the subframe caused it to break. Need to redesign the subframe to be under the upright. Might be better to just start over with a new subframe. 1 Share this post Link to post Share on other sites
bo dawg 518 #6 Posted October 27, 2020 6 hours ago, bcgold said: Arc 700. Thats a whole different loader there. Bigger and Heavier. 1 Share this post Link to post Share on other sites
bo dawg 518 #7 Posted October 27, 2020 Guys I appreciate the input, but I already know how to fix and improve it. My question was is it "Ark 508" factory correct? Plus if I add support I will block the oil drain plug thats on the bottom unless I drill and tap a plug at the side. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #8 Posted October 27, 2020 (edited) 14 minutes ago, bo dawg said: Guys I appreciate the input, but I already know how to fix and improve it. My question was is it "Ark 508" factory correct? Plus if I add support I will block the oil drain plug thats on the bottom unless I drill and tap a plug at the side. The loader appears to be factory correct, can't vouch for the sub frame which looks to be a backyard fabrication. The design of the sub frame defies the laws of engineering. Edited October 27, 2020 by bcgold Share this post Link to post Share on other sites
bc.gold 3,406 #9 Posted October 27, 2020 Hope this answers your question. 1 Share this post Link to post Share on other sites
Skipper 1,789 #10 Posted October 27, 2020 Newer understood why there is no consistency in the way these loader setups are often put together. Often you see a strong build loader with over dimensioned uprights, connected to a flimsy subframe with a single bolt, and a small tube bashed flat in the ends as the diagonal to the low front, which is actually the key piece of kit here to transfer the load into the right places. The loader it self often looks fairly OK. BUT the single bolt to the subframe is like a bicycle chain link in a motorcycle chain. Then the diagonal to the front - that thing often needs to take up pretty much all the forces you put onto that loader, including slamming the machine into something solid. If it breaks, or the small bolts break, the loader comes a lot closer to the operator. I would have made those two parts, or at least the joints of these parts, a lot stronger. Didn't mean to make this a bash against loaders. I love loaders, but when my sense of self preservation cringes toes, I can't help but speak my mind. 3 Share this post Link to post Share on other sites
bc.gold 3,406 #11 Posted October 27, 2020 (edited) 5 hours ago, bcgold said: Plus if I add support I will block the oil drain plug thats on the bottom unless I drill and tap a plug at the side. McMaster-Carr Low-Pressure Iron and Steel Threaded Pipe Fittings Use these fittings for low-pressure applications in noncorrosive environments. Adapters for tanks create an inlet or outlet connection on the surface of any tank, pressure vessel, or drum. Adapters with weld end allow for a permanent connection. Adapters with extension fit tightly into the hole, which keeps the fitting steady during welding. NPTF (Dryseal) threads, NPSC (National Pipe Straight Coupling) threads, and NPSL (National Pipe Straight Locknut) threads are compatible with NPT threads. For technical drawings and 3-D models, click on a part number. Straight Adapters with Extension for Flat Tanks For Use With: Diesel Fuel, Gasoline, Oil, Water Specifications Met: ASTM A181, ANSI/ASME B1.20.1 Pipe Size For Hole Dia. OD Lg. Material Each NPT Female × Weld 1/8 15/16" 1 5/16" 3/8" Steel 12555K79 $3.16 1/8 15/16" 1 1/2" 9/16" Steel 12555K69 3.70 1/4 15/16" 1 5/16" 3/8" Steel 12555K81 2.48 1/4 15/16" 1 1/2" 9/16" Steel 12555K71 3.70 3/8 15/16" 1 5/16" 3/8" Steel 12555K82 3.20 3/8 15/16" 1 1/2" 9/16" Steel 12555K72 3.23 1/2 1 1/8" 1 5/8" 7/16" Steel 12555K83 3.55 1/2 1 1/8" 1 3/4" 5/8" Steel 12555K73 3.23 3/4 1 5/16" 1 15/16" 1/2" Steel 12555K84 3.92 3/4 1 3/8" 2 1/8" 11/16" Steel 12555K74 4.00 1 1 5/8" 2 3/8" 3/4" Steel 12555K75 5.40 1 1 11/16" 2 1/4" 9/16" Steel 12555K85 5.38 1 1/4 2" 2 9/16" 9/16" Steel 12555K86 8.60 1 1/4 2" 2 11/16" 3/4" Steel 12555K76 5.70 1 1/2 2 1/4" 2 13/16" 9/16" Steel 12555K87 8.28 1 1/2 2 1/4" 3" 3/4" Steel 12555K77 8.53 2 2 5/8" 3 3/8" 5/8" Steel 12555K88 8.32 2 2 5/8" 3 1/2" 27/32" Steel 12555K78 10.12 2 1/2 3 1/8" 4 1/16" 1" Steel 12555K89 13.28 3 3 5/8" 4 5/8" 1" Steel 12555K91 14.02 4 4 11/16" 5 13/16" 1 7/32" Steel 12555K92 20.68 Straight Adapters for Flat Tanks For Use With: Diesel Fuel, Gasoline, Oil, Water Specifications Met: ANSI/ASME SA105, ANSI/ASME SA181-70 Pipe Size For Hole Dia. OD Lg. Material Each NPT Female × Weld 1/4 3/4" 1 1/4" 5/16" Steel 12555K51 $6.78 3/8 15/16" 1 1/4" 3/8" Steel 12555K52 9.18 1/2 1 1/8" 1 1/2" 1/2" Steel 12555K53 4.31 3/4 1 3/8" 1 3/4" 5/8" Steel 12555K54 4.31 1 1 11/16" 2 1/8" 5/8" Steel 12555K55 4.75 1 1/4 2" 2 1/2" 3/4" Steel 12555K56 6.58 1 1/2 2 3/8" 3" 3/4" Steel 12555K57 9.93 2 2 7/8" 3 1/2" 13/16" Steel 12555K58 11.43 2 1/2 3 1/2" 4 1/4" 1" Steel 12555K59 16.00 3 4 1/8" 4 3/4" 1" Steel 12555K61 18.72 4 5 1/8" 5 3/4" 1 3/16" Steel 12555K62 31.70 Straight Adapters for Curved Tanks For Use With: Diesel Fuel, Gasoline, Oil, Water Pipe Nipples and Pipe: Use Schedule 40 steel Pipe Size For Hole Dia. For Tank OD OD Lg. Material Each NPTF Female × Weld 3/4 1 1/8" 20" 2 3/16" 7/16" Steel 1698T11 $2.81 NPSC Female × Weld 1 1/4 1 11/16" 36" 2 13/16" 1/2" Steel 1698T12 3.38 1 1/2 1 15/16" 36" 3 1/4" 1/2" Steel 1698T13 3.75 2 2 7/16" 26 1/2" 3 11/16" 5/8" Steel 1698T14 3.78 Edited October 27, 2020 by bcgold 1 Share this post Link to post Share on other sites
wallfish 18,127 #12 Posted October 27, 2020 My guess is the previous owner found out it bends there when the front supports aren't attached or attached correctly. With a loaded bucket the weight and force is on those angle supports to the front so a major crazy connection where you have pictured is not completely necessary. The design is so it can be removed from the tractor quickly and easier. With the front angle supports in place correctly, it's doubtful you could bend that lower connection with the original hydraulics if you tried. I would beef up the front support those angle supports go to on the front of the tractor since that is what takes all the load. 1 Share this post Link to post Share on other sites
953 nut 60,074 #13 Posted October 27, 2020 (edited) My Johnson loader has a heavier sub-frame, but the attachment point looks about the same. Edited October 27, 2020 by 953 nut 1 Share this post Link to post Share on other sites
bo dawg 518 #14 Posted October 27, 2020 4 hours ago, wallfish said: My guess is the previous owner found out it bends there when the front supports aren't attached or attached correctly. With a loaded bucket the weight and force is on those angle supports to the front so a major crazy connection where you have pictured is not completely necessary. The design is so it can be removed from the tractor quickly and easier. With the front angle supports in place correctly, it's doubtful you could bend that lower connection with the original hydraulics if you tried. I would beef up the front support those angle supports go to on the front of the tractor since that is what takes all the load. That makes sense! Theres been more steel welded to the ends of the brackets where your arrow points to. This thing was worked too hard at some point in its life I believe. Share this post Link to post Share on other sites
bo dawg 518 #15 Posted October 27, 2020 8 hours ago, bcgold said: Hope this answers your question. Yep looks like the same sub frame I have and attachment point. Thanks! 1 Share this post Link to post Share on other sites
