Ronnie Gray 1 #1 Posted October 23, 2020 Looking for manual for 310-8 wheel horse tractor. Can’t read model # but it has Koehler 10 hp mod#241S with serial #14221173. Tractor didn’t have deck belt when I got it and am also trying to find belt # and length. I think it’s 101 inches but not sure. Would appreciate any help. Thanks 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,297 #2 Posted October 23, 2020 Your 310-8 tractor is most likely a 1985 model number 21-10K801 because Kohler made the engine in 1984. 1985 was the first year for the 300-Series tractors. What is the width of cut of the deck? Not the width of the deck. 36", 42" or 48". There was also a later 37" side discharge mower with just two blades. Side or rear discharge? We do not have an operator manual for the 1985 model. This early 86 manual should work for you as it was replaced by a second version to correct oil capacities for the new in 1986 low engine oil system you will not have. This one for 1986 has service info that applies to the earlier and later models. Not many tractor service manuals were ever published. These come up on a search for the 21-10K801 https://www.wheelhorseforum.com/search/?q=21-10k801&quick=1&type=downloads_file Garry 1 Share this post Link to post Share on other sites
