seven 202 #1 Posted October 22, 2020 Would someone be so kind as to send me a picture of where the angle adjust rod is supposed to connect up to the blade I think I'm missing something by the way I love all you great wheelhorse people 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #2 Posted October 22, 2020 The rod connects up through the bottom at blade end. Here is a shot from an owner manual. Garry Share this post Link to post Share on other sites
Ed Kennell 45,039 #3 Posted October 22, 2020 Good luck installing the hairpin clip. 1 Share this post Link to post Share on other sites
peter lena 9,782 #4 Posted October 22, 2020 SEVEN, follow the directions above , a detail would be to add flat washers to reduce the wobbly fit , use a hairpin clip cotter pin, never sieze the pin hole , and grease the " steering quadrant " with grease for easy movement , along with lever movement points , should move smooth and easy , pete Share this post Link to post Share on other sites
peter lena 9,782 #5 Posted October 22, 2020 SEVEN , use long nose needle nose plyers , for pin clip, pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #6 Posted October 22, 2020 Don't use a spring pin at the rear. I did and it got knocked out. No problem going ahead - just dragged the rod. When I backed up the rod went down into the ground about 2 feet in a perfect C-shape. Had to disconnect the rod to move the tractor so I could dig out the rod. It now has a cotter pin. Garry 2 1 Share this post Link to post Share on other sites
seven 202 #7 Posted October 23, 2020 Ok needle nose pliers and hairpin clip I think I can handle this . Hopefully the wife has a few clips 😜 1 Share this post Link to post Share on other sites
peter lena 9,782 #8 Posted October 23, 2020 seven, found using 2 , milk crates to elevate and support the plow and frame set up , is the best way to service it . the elevation lets you move around it , and verify function and improvements , adding washers and lubrication at all movement points . by the way , use the 1/8 " hair pin clips on the rear frame mount area holes , lubricate them and push thru till they are on the curved ring part , ensuring they won't fall out. you should be able to verify , smooth and easy ( steering quadrant ) function as well as lever rod operation while up on those milk crates . if it moves smoothly and easily on the crates , that's how it will work on your tractor , just my own experience, pete Share this post Link to post Share on other sites
peter lena 9,782 #9 Posted October 23, 2020 seven, this what you want a for secure pin mount , https://www.walmart.com/ip/DAYTON-EW-45-Hairpin-Clip/577373787?wmlspartner=wlpa&selectedSellerId=1122&&adid=22222222227119734668&wl0=&wl1=g&wl2=c&wl3=233643081001&wl4=pla-383698787660&wl5=9003310&wl6=&wl7=&wl8=&wl9=pla&wl10=101593696&wl11=online&wl12=577373787&veh=sem&gclid=CjwKCAjw_sn8BRBrEiwAnUGJDvdJUtZmBJde30z-N0JxazHgG5tn0CO16IUpFPBm03pf8te2e5XUWhoCcSwQAvD_BwE, they work, pete Share this post Link to post Share on other sites
