ebinmaine 78,453 #51 Posted January 10, 2021 Holy Overdrive Batman!!! Whatsya pulley sizes there mistah?? 1 1 Share this post Link to post Share on other sites
Greentored 3,220 #52 Posted January 10, 2021 12 minutes ago, ebinmaine said: Holy Overdrive Batman!!! Whatsya pulley sizes there mistah?? 8/4. It’s a little much, will probably drop to a 6 up front. It’ll run a good 5mph in low range 3 haha. Id leave it and just run in lower gears on trails and save high 3 for the occasional blast, but can’t help but think of that poor input shaft zinging almost 3x the engine speed haha. I want this thing to last! 1 Share this post Link to post Share on other sites
8ntruck 8,794 #53 Posted January 10, 2021 On 12/19/2020 at 9:30 PM, Greentored said: Got some bills to pay and need to move some Horse inventory, but raided the parts and made a little progress. Going to run a C gas tank out back in tandem with the B tank. No 30mph wheelie machine this time ha, going more for a 15-18mph utility machine. Pretty sure it’s gonna be Kohler powered since I have somehow acquired a stack of K301s. Since it started as a B100, think I’ll name it the B-1 bomber! Going to build yourself a bone then. Share this post Link to post Share on other sites
Greentored 3,220 #54 Posted January 23, 2021 Update: first shakedown woods run! IMG_2215.MOV 2 1 Share this post Link to post Share on other sites
ebinmaine 78,453 #56 Posted January 23, 2021 VERY nice 1 Share this post Link to post Share on other sites
Greentored 3,220 #57 Posted January 23, 2021 10 hours ago, ebinmaine said: VERY nice Thanks buddy! Still plenty to do- theres a lot of masking tape and zip ties holding things they shouldn't ha. OH- and went to a 5" on the trans, so 8/5- MUCH better. Low range is still relatively 'crawling', and maybe 15-16mph flat out in high. Plenty. 4 Share this post Link to post Share on other sites
Greentored 3,220 #58 Posted January 23, 2021 (edited) deleted post- wrong thread Edited January 23, 2021 by Greentored Share this post Link to post Share on other sites
AHS 1,675 #59 Posted January 23, 2021 24 minutes ago, Greentored said: Thanks buddy! Still plenty to do- theres a lot of masking tape and zip ties holding things they shouldn't ha. OH- and went to a 5" on the trans, so 8/5- MUCH better. Low range is still relatively 'crawling', and maybe 15-16mph flat out in high. Plenty. Holy! 15-16 mph! That’s plenty fast for as wide as it is! 2 Share this post Link to post Share on other sites
ebinmaine 78,453 #60 Posted January 23, 2021 25 minutes ago, Greentored said: Thanks buddy! Still plenty to do- theres a lot of masking tape and zip ties holding things they shouldn't ha. OH- and went to a 5" on the trans, so 8/5- MUCH better. Low range is still relatively 'crawling', and maybe 15-16mph flat out in high. Plenty. I have a pulley math site saved on the PC. I need to figure out what to do for Colossus. I have a 3.5" (I think) engine pulley. Transmission pulley on it right now is waaaay too small. Might take some experimentation. Share this post Link to post Share on other sites
Greentored 3,220 #61 Posted January 25, 2021 On 1/23/2021 at 8:16 AM, ebinmaine said: I have a pulley math site saved on the PC. I need to figure out what to do for Colossus. I have a 3.5" (I think) engine pulley. Transmission pulley on it right now is waaaay too small. Might take some experimentation. 1:1 pulley ratio is real nice for a worker and enough speed to have a little fun- maybe 8-9mph with a 23" tire. Thats where I ended up on Hoss (5/5) and really like it! I scribbled down a quick 'calculator'- if you can decipher this its pretty close. Divide engine pulley by trans pulley, multiply by engine rpm. This is trans input speed. Divide that number by 24.6 = axle rpm Divide that number by 88 (axle rpm required for 6mph) Multiply that number by 6 = speed this is for 23" tires. For taller tires, divide by 23, multiply that number by your speed calculation. Example: 8/5 pulleys on the B-1, 3000 engine rpm (still farting around with governor and throttle). 8/5= 1.6. x 3000rpm = 4800 input rpm 4800/24.6= 195 axle rpm 195/88 = 2.21 2.21 x 6 = 13.2mph. The B-1 runs 13mph on phone gps. 2 Share this post Link to post Share on other sites
Pullstart 69,864 #62 Posted January 25, 2021 Looks like ya found a sapling or four Scott 1 Share this post Link to post Share on other sites
ebinmaine 78,453 #63 Posted January 25, 2021 10 hours ago, Greentored said: 1:1 pulley ratio is real nice for a worker and enough speed to have a little fun- maybe 8-9mph with a 23" tire. Thats where I ended up on Hoss (5/5) and really like it! I scribbled down a quick 'calculator'- if you can decipher this its pretty close. Divide engine pulley by trans pulley, multiply by engine rpm. This is trans input speed. Divide that number by 24.6 = axle rpm Divide that number by 88 (axle rpm required for 6mph) Multiply that number by 6 = speed this is for 23" tires. For taller tires, divide by 23, multiply that number by your speed calculation. Example: 8/5 pulleys on the B-1, 3000 engine rpm (still farting around with governor and throttle). 8/5= 1.6. x 3000rpm = 4800 input rpm 4800/24.6= 195 axle rpm 195/88 = 2.21 2.21 x 6 = 13.2mph. The B-1 runs 13mph on phone gps. If I use that formula I should be around 9 or 10 MPH wide open. That's plenty fast. I'll set a minute sometime and figure what's what... 1 Share this post Link to post Share on other sites
tom2p 2,394 #64 Posted January 26, 2021 On 1/22/2021 at 8:42 PM, Greentored said: Update: first shakedown woods run! IMG_2215.MOV my kind of fun ! we did this often at one time sometimes with a small farm tractor first and me following with a Wheel Horse 704 front part of the 704 hood a little beat up - but took a lickin and kept on tickin ! 1 Share this post Link to post Share on other sites
Greentored 3,220 #65 Posted January 27, 2021 On 1/25/2021 at 6:13 PM, pullstart said: Looks like ya found a sapling or four Scott Making my own new trails! So far I've found 1.5" dia is the 'live sapling cutoff'- anything under, run it down. Anything over, its gonna climb it first, then MAYBE continue over it. Brush guard coming next ha. 1 1 Share this post Link to post Share on other sites
Greentored 3,220 #66 Posted February 21, 2021 More updates: made some linkage and hooked the brakes up to the deck lift arm, fabbed up a dual throttle setup (dash and foot) and threw some 19x7 and 26x9 atv tires on. This thing is a beast! 5 4 2 Share this post Link to post Share on other sites
ebinmaine 78,453 #67 Posted February 21, 2021 I like it!! 1 Share this post Link to post Share on other sites
Pullstart 69,864 #68 Posted February 22, 2021 I think you need an Arsenal of trail bombers... for when Horse Fellers visit! 1 1 Share this post Link to post Share on other sites
OldWorkHorse 3,131 #69 Posted February 22, 2021 9 hours ago, Greentored said: More updates: What is the speed on sumthing like this and pully sizes ur running? I'm building somthing like this and just trying to see what pulleys work well for people. 3 1 Share this post Link to post Share on other sites
Greentored 3,220 #70 Posted February 22, 2021 1 hour ago, OldWorkHorse said: What is the speed on sumthing like this and pully sizes ur running? I'm building somthing like this and just trying to see what pulleys work well for people. I have an 8 on the engine and 5 on the trans, it runs 16mph on gps with the 26” tires, at 3000 rpms. 7/5 seems to be the standard for the guys trail running Horses. You can run a smaller trans pulley but they can slip if you get into mud or water👍 1 3 Share this post Link to post Share on other sites
Greentored 3,220 #71 Posted March 1, 2021 The B-1 went on it’s first group ride on Saturday! Fouled a plug, followed by a ‘not charging’ issue which was a loose connection at the regulator. Replaced the plug, then later shorted one of the wires and killed the regulator. Threw a new battery in and rode the rest of the day without a hiccup! Stay tuned- there’s a lot more to come on the ol bomb. 2 1 Share this post Link to post Share on other sites
Greentored 3,220 #72 Posted March 1, 2021 We love our horses best but respect these other bombers too. That yellow machine is an animal, powered by a fully built, 5000rpm K341, making close to 30hp! 4 Share this post Link to post Share on other sites
ebinmaine 78,453 #73 Posted March 1, 2021 I think it's awesome that you folks put time and energy into older machines and go out and play. Good old heavy American iron that will last. 1 1 Share this post Link to post Share on other sites
slim67 2,825 #74 Posted March 1, 2021 6 hours ago, Greentored said: We love our horses best but respect these other bombers too. That yellow machine is an animal, powered by a fully built, 5000rpm K341, making close to 30hp! Is that mister studabaker? if so , its definitely bad ass. 2 Share this post Link to post Share on other sites
19richie66 17,869 #75 Posted March 1, 2021 Looks like his machine.👍 2 Share this post Link to post Share on other sites
