mikeR 0 #1 Posted May 18, 2009 Evening, all I have a C-175, 1984 vintage, with the Kohler KT-17S twin. When I changed the oil and put the mower deck on it last month, the spark plugs were loose- as in finger loose. I tightened them up- with great fear of stripping an aluminum head- and mowed with it. After second mowing, plugs are loose again (crap!). Any solutions other than inserts or new heads? Heads still have threads, and tighten up. Mike from Florida Share this post Link to post Share on other sites
Coadster32 793 #2 Posted May 18, 2009 New plugs with new crush washer attached. It acts like a lock washer. I don't think thread locker would be good in this case. Good luck. Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted May 18, 2009 Try new plugs , but if you need heads get with me I'll make you a good deal on a pair. Share this post Link to post Share on other sites
Coadster32 793 #4 Posted May 18, 2009 If the heads are the problem, you could heli-coil them out. (hardened inserts). If the plugs are really loose while threading them in or out, chances are this would fix the problem. New plugs is where to start though. Share this post Link to post Share on other sites
mikeR 0 #5 Posted May 26, 2009 Thanks for the advice, all. Pulled out the manual; the sales person had highlighted all the service for the tractor (back in 1984). He had written in several plug choices- I got a set of Autolite 26's, and put them in. Shoulder was completely different than the Lowes plugs I had put in when I got the tractor- and the Autolites went down solid. Since the tractor had been running crappy, I decided to check the points- did a light buff with emery cloth and then the engine wouldn't start. Got out the feeler gauges, set the points carefully to 0.020- no go. Ended up doing the old style tap-and-try, finally got it running, locked the screw down and closed the cover. Running with incorrect gap setting sure beats not running with correct spec setting.... Share this post Link to post Share on other sites
