TC10284 114 #1 Posted October 1, 2020 (edited) Today I prepped up my 314-8 to mow tomorrow and found that my 42" Side Discharge deck center grease fitting is not accepting anymore grease. I tried replacing the grease fitting with a new one and it didn't make a difference. I can get a small squirt into it, but a second squirt and third gets harder until I can't squeeze any harder. Then the grease will just come out of the end of the grease gun tip when I start to disconnect it. Not sure what's going on here unless it is plugged up with dirt or something. It didn't do this the last time I used it earlier this year. The only thing I've done is take off blades to sharpen them and put back on. I even took the center blade off the deck thinking I tightened it too much and tried that way, but same result. Edited October 1, 2020 by TC10284 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #2 Posted October 1, 2020 Does this apply to your deck? Garry 1 Share this post Link to post Share on other sites
peter lena 9,893 #3 Posted October 1, 2020 TC10284, agree with g west above on that possible issue, but I would also remove the fitting and use a solid wire to probe the depth of the bearing shaft hole , that acts as flow point for lower bearing grease , pete Share this post Link to post Share on other sites
TC10284 114 #4 Posted October 1, 2020 I checked the model number and it is one of the newer Toro branded decks. The model # doesn't match up. But, later today I will try a wire first and if nothing, try loosening the nut per the advisory. Share this post Link to post Share on other sites
TC10284 114 #5 Posted October 2, 2020 Alright so I took out the grease fitting and stuck a small screwdriver in until it stopped. Didn't find anything other than grease. It definitely has grease - some of the red kind that I ran out of a few months ago. I took off the nut and washer on top of the spindle also, and hit it with a rubber hammer. Didn't seem to help any. Put it all back together and couldn't get more than one pump of grease in. Pics: https://photos.app.goo.gl/8ZFJ37LvWsGZatP77 Share this post Link to post Share on other sites
