"Manic-Mechanic" 1,485 #1 Posted September 25, 2020 Hello, trying to find a picture of this deflector used in the power bagger set up model 79301 power bagger. I can find the part but no pictures! Anyone maybe can shed some light on this? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #2 Posted September 26, 2020 Possibly the part number is 79-7200-03? Item #7 https://www.partstree.com/models/79301-toro-42-48-vacuum-bagger-for-300-series-garden-tractors-sn-220000001-220999999-2002/48in-deck-component-assembly-1/ Garry 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #3 Posted September 26, 2020 (edited) The part is #4 79–7290–03 I can't see it well enough on the diagram-vague. 48" deck 70 bucks is a lot for a bent piece of metal! I got this wear plate 79-2831-03 which goes in that region but seems large? The plate originates on a newer 42" deck, maybe wouldn't do anything on mine? 18115.pdf 6077.pdf Edited September 26, 2020 by oldman Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #4 Posted September 26, 2020 (edited) 54 minutes ago, gwest_ca said: Possibly the part number is 79-7200-03? Item #7 https://www.partstree.com/models/79301-toro-42-48-vacuum-bagger-for-300-series-garden-tractors-sn-220000001-220999999-2002/48in-deck-component-assembly-1/ Garry The 79-7200-03 is the wedge for the belt shield, inner shield. (92-1160) I found another inner shield designed for the 260 tractor blower kit and made it fit that wedge. Then I got the right inner shield after modifying the first one! Da-ha! Hate whenever that happens! Now this deflector is sort of needed to well, "deflect" the outgoing clippings away from that vulnerable spot in the deck, (where they rot out by the two holes). Edited September 26, 2020 by oldman Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #5 Posted September 26, 2020 47.35 here plus what I understand a flat 7.95 shipping charge. Good time to build an order if you need other parts. https://www.psep1.biz/arinet.asp#/s/TO//79-7290/1/ Garry 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,485 #6 Posted September 27, 2020 That's the best price I've seen so far! Share this post Link to post Share on other sites
