Elliot Garfinkel 166 #1 Posted September 25, 2020 Hi all will be looking at one of these machines it's running and has a kohler 12 hp it seems that availability of parts maybe an issue, any input would be appreciated. Share this post Link to post Share on other sites
Stepney 2,357 #2 Posted September 25, 2020 (edited) Hydro or standard? The reversing gear box on the standard models can be troublesome, the hydros were alright mostly.. long as they were maintained. PTO parts electric or manual are both scarce. Pretty much no aftermarket support for these rigs, which is a shame.. Not much to know otherwise, the K is a great engine and they really had no other faults as a tractor.. The implements however leave a lot to be desired.. Edited September 25, 2020 by Stepney Share this post Link to post Share on other sites
Elliot Garfinkel 166 #3 Posted September 26, 2020 Thanks for the response I'm going tomorrow to look owner just said it runs and needs clutch adjustment,I am just guessing that the chief was manual and the super chief was hydro,comes with plow he's asking 275 dont know anything more,really not looking for something I cant get parts for but the motor is worth something. Thanks Share this post Link to post Share on other sites
WHNJ701 4,168 #4 Posted September 26, 2020 @Stepney is any of the early ford stuff interchangeable? Share this post Link to post Share on other sites
Elliot Garfinkel 166 #5 Posted September 26, 2020 I think some might be but just as scarce I think model 120 might be compatible is any of the wheelhorse stuff compatible Thanks Share this post Link to post Share on other sites
Achto 30,844 #6 Posted September 26, 2020 38 minutes ago, Elliot Garfinkel said: wheelhorse stuff compatible The most all of the Kohler engine parts. That would be about it. Share this post Link to post Share on other sites
Stepney 2,357 #7 Posted September 26, 2020 1 hour ago, jabelman said: @Stepney is any of the early ford stuff interchangeable? Jake built the Fords, Olivers, .. some name that was orange which I forget, and MinniMo's so yes, basically everything except the paint and a few trim pieces were interchangeable .. long as they were the same year/style. The engine is a narrow pan usually so even the block is not the same as a WH, its like the style used in an IH Cub Cadet. Share this post Link to post Share on other sites
Elliot Garfinkel 166 #8 Posted September 26, 2020 Ok I might have to pass on it I dont mind a project but I think I'm going to paint myself in a corner. Li,Ny is not tractor friendly Thanks for the help Share this post Link to post Share on other sites
Elliot Garfinkel 166 #9 Posted September 27, 2020 Well I couldn't resist except for battery cover it was all their,Two rear tires were toast guy took 75 off.So it was 200 ,Swears it runs but needed battery, fresh gas so I didn't even try to play around.Their doesn't seem to be any leaks from seals but we will see Share this post Link to post Share on other sites
