The Tuul Crib 7,340 #1 Posted September 25, 2020 (edited) Just picked this up today because I found it on sale. Just exactly how much can be added to the current case of these big block kohlers? Edited September 25, 2020 by The Tuul Crib Share this post Link to post Share on other sites
pfrederi 19,911 #2 Posted September 25, 2020 (edited) Math class time. How much does it say for a car...divide by 5 and then multiply result by 1.5 or 2 (Shallow or regular pan) Edited September 25, 2020 by pfrederi Share this post Link to post Share on other sites
peter lena 9,770 #3 Posted September 25, 2020 tuul crib , i use a couple of ounces of zinc to my oil changes , with very good results, the engine treatment will really get after the varnish and crud build up in your engine , you will notice an oil color change sooner as the hot oil mixture cuts thru the crud . let it work , do not change it out too soon. i have a number of hours on my rislone / kohler clean up , and am very happy with the smooth running and less effort that the engine is now operating at . as above the back of the bottle says amounts for amount of oil , you will get a number of oil changes out of the bottle. it definitely works , pete Share this post Link to post Share on other sites
