mmmmmdonuts
Power bagger
mmmmmdonuts
Not sure if this should be under modifications or implements but my colleague gave me (aka free)  a John Deere power flow bagger last year and I am just now getting around to attempting to install it.
I got the deck blower mounted but I am going to have to buy a longer belt for it. The blower mounted with minimal changes just really drilling 3 holes and adding some spacer washers.
The rear mount is going to be a little more challenging and time consuming. Right now I got it going through the sleeve hitch which is how it normally mounts but now I got to figure out a bracket to hold it in place better. I was thinking two metal plates that sandwich the axles. I am using a tie down right now to hold it in place.
Any thoughts other than what I already have.
Here is a link to the JD mounting setup.
http://manuals.deere.com/cceomview/OMM145411_L0/Output/OMM145411_L06.html#43420
Pardon the messy shed.
Resizer_16006424618160.jpg.da1305f2bd15f74469d51b418ad6bdea.jpgResizer_16006424618161.jpg.e268c4bcf629f1c0b8ebc8d54c9a71eb.jpgResizer_16006424618167.jpg.bc5de4f277ae3cbc7a3bc14669c1bb45.jpgResizer_16006424618166.jpg.d2604533a7c23d66f66b0d4492c180f6.jpgResizer_16006424618165.jpg.c91106472d2009678d43b9cd25f01e29.jpgResizer_16006424618164.jpg.665b49dbfb73756ec66b25f2fea70539.jpgResizer_16006424618162.jpg.006edbc365ee090a6dbf79a647434060.jpgResizer_16006424618163.jpg.ea971b93d8bf7ca91dee5816e7bc3ee5.jpg
danniel
The rear mount is going to be a little more challenging and time consuming. Right now I got it going through the sleeve hitch which is how it normally mounts but now I got to figure out a bracket to hold it in place better. I was thinking two metal plates that sandwich the axles.I am using a tie down right now to hold it in place.
My friend has a 2013 model JD 100 series tractor. It took about 2 days to wear the bagger. The user manual on the John Deere official website unfortunately does not provide accurate and sufficient information. Congratulations if you succeeded by looking at this manual.
