W/H JUNKY 43 #1 Posted September 17, 2020 Hello everyone. I was hoping to get alittle help on this. Iam looking for the interlock switch for a. 01-17KE02. I believe the part number is 103480. Does anyone know where I might be able to purchase one. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,987 #2 Posted September 18, 2020 This is the neutral switch for the starter and no longer available from Toro but you likely already knew that. Some have replaced it with a switch available for a refrigerator but do not know the success rate. The type of switch you need is "Normally Open" or "NO" Click on the picture for more pictures. Garry Share this post Link to post Share on other sites
WHX?? 54,619 #3 Posted September 18, 2020 Put an ad in wanted. Possible guys may have one off a parts tractor. Share this post Link to post Share on other sites
RJ Hamner 1,029 #4 Posted September 18, 2020 Having been down this road recently I can tell you the two options available. 1. As WHX24 related use the Wanted Classified or you can probably get one from AZ Tractor he had some last time I checked 2. You can convert the tractor to use the switch that is operated by the clutch pedal. It’s a fairly simple swap and those parts are available either new or from AZ Tractor And NO I am not a salesman for AZ Share this post Link to post Share on other sites
AMC RULES 37,254 #5 Posted September 18, 2020 What is it that makes that switch fail? Doesn't it live protected under tins? Share this post Link to post Share on other sites
W/H JUNKY 43 #6 Posted September 18, 2020 Thank you guys for the replys. I sure do appreciate it. Share this post Link to post Share on other sites
RJ Hamner 1,029 #7 Posted September 18, 2020 9 minutes ago, AMC RULES said: What is it that makes that switch fail? Doesn't it live protected under tins? Probably they same reason your knees give out even though they a covered by your pants? 2 2 Share this post Link to post Share on other sites
