mowboy 12 #1 Posted September 16, 2020 I want to change engines on my 310-8. Currently on this tractor is a Kohler K241S spec#46863 and I want to change it to a K241S spec #46636D. Other than the oil drain plug being underneath the engine (on the 46636D) does anyone know if there are any other differences that will prevent a direct swap? Or can you tell me where to look for the differences? Thanks for any info-- Share this post Link to post Share on other sites
pfrederi 19,896 #2 Posted September 16, 2020 Both were made for Wheel horse. As long as they are both battery ignitions I don't see any issue. 1 Share this post Link to post Share on other sites
953 nut 64,127 #3 Posted September 16, 2020 You could leave your oil pan on the frame and bolt the other engine to it if the oil drain would be a problem. Share this post Link to post Share on other sites
tunahead72 2,617 #4 Posted September 19, 2020 Your current engine has a low oil sensor, the other one (older spec.) probably doesn't. That won't cause any problems, just something to be aware of. Personally, I can easily do without the sensor on my 310-8 (same engine), and will remove it if I decide to rebuild it again. Share this post Link to post Share on other sites
mowboy 12 #5 Posted September 21, 2020 Thanks to all ! Share this post Link to post Share on other sites
