Tractorhead 9,215 #1 Posted September 13, 2020 Hi, i need help in find replacements for the bearings and Oil- Seals on the RMR 3226 Deck i like to rework few of them, because few bearings have little of play in it and the Seals doesn‘t work as needed. Any help here from the experienced will be highly appreciated. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,888 #2 Posted September 13, 2020 Is this the deck you have? RMR-3226? Garry Share this post Link to post Share on other sites
Tractorhead 9,215 #3 Posted September 13, 2020 Yes, that is the Deck i have sorry of the misstyped numbers. Rmr 3262 was the right. i search for values, where i can get here at my side exchange parts ( bearings and oilseals) from SKF or *** Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,888 #4 Posted September 13, 2020 Taken from notes so check to see if they are correct 1508 is a Torrington B-1212 needle bearing - 4 required 1515 replaced by 101480 and may be a SKF 1630-2RS ball bearing - 2 required Bearing Needle Radial .750"x1.250"x.078" Torrington NTA-1220, Used on gear driven mower decks 99-3836 Replaces Wheel Horse 1534, 8571, 33589, 701021 Flat thrust bearing - 2 required Bearing Needle Radial .750"x1.250"x.030" Flat race Torrington TRA-1220, Used on gear driven mower decks Used with 99-3836, 1534, 8571, 33589, 701021 bearings Wheel Horse 1535 Flat thrust race - 4 required 1303 seal - 2 required for deck and 1 required for idler pulley SKF 7410 Garry 1 Share this post Link to post Share on other sites
Tractorhead 9,215 #5 Posted September 14, 2020 Thanks Garry, that helps me a lot to build my resto-part Shopping list.. 👍 Share this post Link to post Share on other sites
