71_Bronco 1,072 #1 Posted September 13, 2020 Finally saved enough pennies to get a set of rear tires for my Lawn Ranger. I upped the size of the fronts by 2" in the diameter, so i was going to up the rears by 2" as well. That would make my rears 18x8.50-8 or 18x9.50-8. I'm not planning on using this tractor for anything other than a fun rider (no mowing or anything). I MAY decide to throw the plow back on, but it would only be for fun / show. I was looking at tire sizes, and noticed I can also get 20x10-8 tires. I already have a set of 8 inch wheels, so I'm working with that constraint. 20x10-8 would probably look massive on this tractor (not a bad thing). What do you guys think? Step up to 20's? Or stay at 18's? The tires on it now at 16" diameter roughly (4.80-8"). Share this post Link to post Share on other sites
953 nut 65,058 #2 Posted September 13, 2020 49 minutes ago, 71_Bronco said: 18x9.50-8. This would get my vote. 2 Share this post Link to post Share on other sites
Skipper 1,792 #3 Posted September 13, 2020 (edited) Tires too big? ------- NO such thing I put 20/10-8 Aggs on my crapsman scrub mower, just because. Fill those with water, and they will also work as weights :-). To me the question is more like: Can these clear the fenders? Can these also allow room for your implements? But you can't trust me on this. I'm a notorious BBM (Big But Man) ------- on tractors that is! Edited September 13, 2020 by Skipper 1 1 2 Share this post Link to post Share on other sites
71_Bronco 1,072 #4 Posted September 13, 2020 I do have to check the fenders. I want them to fit under the little rolled lip. I think im going to have to make a new box that the fenders mount to. I bought neutral offset wheels so the insides would come closer together, rather than making the overall width bugger (I like the look, like a tubbed pro-street car). 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #5 Posted September 13, 2020 I would vote for the 20 i have on my 212 Horse 18 x 8,5 x 8“ on the rear. a bit more will help increase ground speed and give you more clearance. few pict‘s to compare 2 3 Share this post Link to post Share on other sites
Roger R 473 #6 Posted September 13, 2020 I always like to see the biggest, widest that will fit! Tires make or break the look. (Other than a factory original restore) Share this post Link to post Share on other sites
71_Bronco 1,072 #7 Posted September 13, 2020 Just checked the fenders, 2" bigger will fit fine, 4" may be cutting it too close to the fenders. I think 18" tires will be the ticket. 2 Share this post Link to post Share on other sites
71_Bronco 1,072 #8 Posted September 18, 2020 Well, Just bit the bullet and ordered a set. Went with the 18x9.50-8 tires, Carlisle "Super Lug". Should look nice on the black 8.5" wide wheels I was originally going to get a set of the OTR "Lawn Trac" tires, as I like the more squared profile of the edges, and the curved bar style. I think they look better than the Carlisles. However, they are only offered in 18x8.50-8 size, and I was concerned about the width of the tire vs the width of my wheels. I probably would have been okay, but I figured the Carlisles would be a safer bet. Plus I have Carlisle tires on the front, and I'm a little OCD about stuff like that. Here's the Lawn Tracs 2 Share this post Link to post Share on other sites
