GarySeever 82 #1 Posted September 13, 2020 Workhorse 800 will not turn over with the switch. It will turn over if you hook jump box to the starter. But still no spark to the plug. Any help would be appreciated. Share this post Link to post Share on other sites
Tractorhead 9,217 #3 Posted September 13, 2020 + check all fuses if they intact and safety switches if they work proper. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,068 #4 Posted September 13, 2020 You realize the magneto ignition is self-powered? Do not apply battery power to the ignition wire. That will burn up the coil. Garry Share this post Link to post Share on other sites
GarySeever 82 #5 Posted September 13, 2020 Sorry everyone I told you the wrong information on the wheelhorse it is a commando 800 . I thought that electric diagram looked different thanks again Share this post Link to post Share on other sites
953 nut 64,651 #6 Posted September 13, 2020 OK, take a look at this wiring diagram. Share this post Link to post Share on other sites
GarySeever 82 #7 Posted September 14, 2020 Yep that's the one. bad wire on the clutch switch. Fires right up now. Thanks again 1 Share this post Link to post Share on other sites
