Achto 32,883 #26 Posted September 19, 2020 Mind if I pull up a chair for this show? 3 Share this post Link to post Share on other sites
Oldskool 6,678 #27 Posted September 19, 2020 1 hour ago, ebinmaine said: The way oldskool works he'll have six or seven customs done before I get Colossus finished Oh come on now. You cant be to far off from being done. Share this post Link to post Share on other sites
ebinmaine 81,036 #28 Posted September 19, 2020 7 minutes ago, Oldskool said: Oh come on now. You cant be to far off from being done. Hehehehe. Let's just say I'm still closer to the beginning than the completion. 1 3 Share this post Link to post Share on other sites
Oldskool 6,678 #29 Posted September 19, 2020 3 hours ago, ebinmaine said: Hehehehe. Let's just say I'm still closer to the beginning than the completion. Well another winter is upon us. Maybe get some done then? Share this post Link to post Share on other sites
ebinmaine 81,036 #30 Posted September 19, 2020 1 hour ago, Oldskool said: Well another winter is upon us. Maybe get some done then? Oh yeah. Absolutely. Been busier 'n' a one armed wallpaper hanger with an itchy back. Got a couple in front of it but we'll get 'er cookin for next spring's logging. 2 Share this post Link to post Share on other sites
Oldskool 6,678 #31 Posted September 19, 2020 Ah mud season lol 1 Share this post Link to post Share on other sites
ebinmaine 81,036 #32 Posted September 19, 2020 3 minutes ago, Oldskool said: Ah mud season lol Ayuh. 1 Share this post Link to post Share on other sites
Oldskool 6,678 #33 Posted September 20, 2020 Well today's progress was getting the rear axle mounted, the brake linkage made and working in conjunction with the linkage to neutral out the trans. Also hooked up the forward/reverse lever and mocked up a running board 2 3 1 Share this post Link to post Share on other sites
8ntruck 9,358 #34 Posted September 20, 2020 On 9/18/2020 at 7:01 PM, Oldskool said: Well you got me there. I do NOT have a plan for that We can help you with a plan. How about over and under lights on the dual headlight side. 2 Share this post Link to post Share on other sites
8ntruck 9,358 #35 Posted September 20, 2020 On 9/18/2020 at 7:01 PM, Oldskool said: Well you got me there. I do NOT have a plan for that We can help you with a plan. How about over and under lights on the dual headlight side. 1 Share this post Link to post Share on other sites
Lee1977 7,807 #36 Posted September 20, 2020 18 minutes ago, 8ntruck said: We can help you with a plan. How about over and under lights on the dual headlight side. That will work. Anyway you want to install them, just need two on the right, 3 2 Share this post Link to post Share on other sites
Oldskool 6,678 #37 Posted September 22, 2020 Back to tin knockin. Starting on the hood now. Not sure which route I will go. Maybe RJ style or 401, or 753. Any input would be great 4 4 1 Share this post Link to post Share on other sites
ebinmaine 81,036 #38 Posted September 22, 2020 I don't know much about the differences on the round Hood models so I really can't comment but I just got to say I'm real impressed with the amount of work you've got into that already. It looks great. 3 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,760 #39 Posted September 22, 2020 1 1 Share this post Link to post Share on other sites
Oldskool 6,678 #40 Posted September 22, 2020 7 minutes ago, ebinmaine said: I don't know much about the differences on the round Hood models so I really can't comment but I just got to say I'm real impressed with the amount of work you've got into that already. It looks great. Thanks. I try to make as much progress as I can in what little extra time I have. Family, work, second job and then playtime lol. The differences between the hoods in this case would be how I end it at the steering shaft. Thinking I want the hood to flip forward for maintenance 4 Share this post Link to post Share on other sites
ebinmaine 81,036 #41 Posted September 22, 2020 11 minutes ago, Oldskool said: . Thinking I want the hood to flip forward for maintenance I would most certainly agree with that. Just to throw it out there, another option you have is what I'm going to do on Colossus. Battery and gas tank are going to be on a bracket out in front of the hood so it won't be able to tilt forward. Long removable pin through the front hood hinge pin holes. 1 Share this post Link to post Share on other sites
Oldskool 6,678 #42 Posted September 22, 2020 18 minutes ago, ebinmaine said: won't be able to tilt forward. Long removable pin through the front hood hinge pin holes. The long pin idea could very well work. I think my battery will be tucked in under the seat. but as far as the gas tank goes. Well not sure where that will go yet. 1 Share this post Link to post Share on other sites
ebinmaine 81,036 #43 Posted September 22, 2020 7 minutes ago, Oldskool said: The long pin idea could very well work. I think my battery will be tucked in under the seat. but as far as the gas tank goes. Well not sure where that will go yet. In my case as you know I'm going for a particular look and I have a tank that I really want to have outside so you can see it. I can't remember specifically but I think I got the idea from looking at the way the plows were held onto the frames. Share this post Link to post Share on other sites
ebinmaine 81,036 #44 Posted September 22, 2020 I don't know what kind of look you're going for with that. I've got a tiny little "gas" tank I would donate to the cause if you were interested in using it. I believe it to be a sixties or seventies vintage fogger for running a tube into the exhaust and spraying insecticide. It's only about 4" diameter by maybe eight long? 1 Share this post Link to post Share on other sites
Oldskool 6,678 #45 Posted September 22, 2020 39 minutes ago, ebinmaine said: I don't know what kind of look you're going for with that. I've got a tiny little "gas" tank I would donate to the cause if you were interested in using it. I believe it to be a sixties or seventies vintage fogger for running a tube into the exhaust and spraying insecticide. It's only about 4" diameter by maybe eight long? I appreciate the offer. I will keep that in mind. I think once things come together a bit more I may have a better handle on what I need. 1 Share this post Link to post Share on other sites
Oldskool 6,678 #46 Posted September 23, 2020 Getting a real good feel of what it's going to look like now 7 1 Share this post Link to post Share on other sites
ebinmaine 81,036 #47 Posted September 23, 2020 Like the steering behind the hood 1 Share this post Link to post Share on other sites
Oldskool 6,678 #48 Posted September 23, 2020 5 minutes ago, ebinmaine said: Like the steering behind the hood It might still be in the hood. I'm not sure yet. I did have to get something built to hold the steering shaft up though. Alot of undecided aspects at the moment 1 Share this post Link to post Share on other sites
bds1984 1,519 #49 Posted September 23, 2020 I like where this build is going. Just one question, do you know what transmission this is? 1 1 Share this post Link to post Share on other sites
Oldskool 6,678 #50 Posted September 23, 2020 Just now, bds1984 said: I like where this build is going. Just one question, do you know what transmission this is? Thanks. I'm not even sure where this build is going LOL The transmission is a 331-3000 hydro gear. 1 Share this post Link to post Share on other sites
