stevasaurus 23,456 #1 Posted May 15, 2009 I took pictures of the decks...wondering which of my tractors they will fit...and identifying the decks to find manuals....they are in pretty good shape...just want to make sure I put the right one on the right horse...thanks the horses are an 857...502...702. I already have a 48" deck mounted on the 1972 raider 10 this is a 32" deck with 2 16" blades this is a 36" deck with 2 18 1/4" blades. It has a tag that looks like RV 3 36 with a serial # 200053 this is a 36" deck with 2 18 1/4" blades, It has a tag that looks like RM 367 with a serial# 292766 I believe the 48" deck is a model 5-1201 or 5-1202 thanks :omg: Share this post Link to post Share on other sites
W9JAB 156 #2 Posted May 15, 2009 his is a 36" deck with 2 18 1/4" blades, It has a tag that looks like RM 367 with a serial# 292766 This wil fit my 856 :omg: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #3 Posted May 15, 2009 The top deck is compatible with the 502 (might be an RMR-3262 or RM-323), the middle can/will work on the 702 but is a bit newer (need the correct model number), and the bottom deck is probably the original deck from the 857. :omg: Share this post Link to post Share on other sites
stevasaurus 23,456 #4 Posted May 15, 2009 thanks guys 69ramrod69...I like your since of humor ...quite honestly, I do not need 4 decks...once I figure this out, if you are serious, I will keep you in mind. TT...this is what we talked about...thanks for your help...if it stops raining, I will check out what fits what next week. Pulled some manuals from the links, but they are not the same model...but close enough to point me in the direction. More worried about the right size belt...let you know. How about I post some pics? :drool: Share this post Link to post Share on other sites
stevasaurus 23,456 #5 Posted May 20, 2009 cleaned up the RM 367 deck last monday...greased, oiled and sharpened the blades. It wasn't easy, but the RM 367 deck went right on the 857. Mowed the lawn after that also got the raider 10 running after cleaning the fuel pup and soaking and cleaning the carb.....what a nice day. :drool: Share this post Link to post Share on other sites
