71_Bronco 1,072 #1 Posted September 9, 2020 Have a 44" (I think) grader blade that I bought for my Bronco 14. It is an aftermarket unit that I thought I bought from someone on here a few years back. It is one that mounts to the rear axle brackets, not the mid-mount tach-o-matic mount. I did mount it on the Bronco 14 before I disassembled it, and I remember it worked fine, and was able to angle the blade without hitting the front tires (if my memory serves me right). If I were to mount that same grader blade on a short-frame tractor, like my Commando 8, would I have any issues? I would think that it would hit my front tires when tilted, but if kept straight, would it work? Or was there a different grader blade specifically for the short-frames? Share this post Link to post Share on other sites
ebinmaine 77,541 #2 Posted September 9, 2020 Seems to me being a custom build you really would just have to try it and see. Short frame to a long frame should be about two and three-quarter inch difference. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #3 Posted September 9, 2020 The first MB-405 in 1965 became the 7-1711 in 1968 and listed for both the short and long frame tractors. This one mounts to the front and is pulled. Garry Share this post Link to post Share on other sites
953 nut 64,330 #4 Posted September 9, 2020 8 hours ago, 71_Bronco said: I would think that it would hit my front tires when tilted, but if kept straight, would it work? You could drill a couple new holes at an acceptable angle that will work for the short frame. Here is a bit more information on the 40" Share this post Link to post Share on other sites
71_Bronco 1,072 #5 Posted September 9, 2020 I'll take a couple pics in the coming days, its at my parents house. From what I recall, its a copy of the Wheel Horse ones. I don't remember why the guy was making repro ones. 1 Share this post Link to post Share on other sites
