mrtom 15 #1 Posted September 7, 2020 I’m a new guy here looking for info! I bought a decent looking Lawn Ranger with the engine missing. I found a nice 1993 H60 for it. I had the base plate from the original engine so it bolts right up and looks to be in the proper position. It does not fit under the hood with the air cleaner on so I’ll need a smaller air cleaner that will fit without the elbow on the carb. I also need to know what size and kind of pulley I’ll need to run the tractor as well as the cutting deck. Any help or advice would be truly appreciated! 1 1 Share this post Link to post Share on other sites
Achto 32,115 #2 Posted September 7, 2020 I'm not real familiar with the Rangers but guys will be along soon with info. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,304 #3 Posted September 8, 2020 i'm not familiar with any Lawn Rangers older than the 68 model...could you show a pic of your ranger? Share this post Link to post Share on other sites
mrtom 15 #4 Posted September 8, 2020 (edited) This white engine was borrowed just to see how it fits. Edited September 8, 2020 by mrtom Unintentionally uploaded video. 1 Share this post Link to post Share on other sites
305 381 #5 Posted September 8, 2020 you have a 1968 Lawn Ranger it's good you have that base, they can be hard to find originally your machine had a 3 groove pulley that was 2-1/2" diameter and had a 1" bore to fit a H60 that had a 1" crankshaft. you see them on that big online auction site sometimes. a lot of H60s you find used came from snow blowers and have 3/4" crankshafts. you will then need to improvise with two 2-1/2" pulleys with 3/4" bore to run the deck and the drive that borrowed engine appears to have the correct Lawn Ranger fuel tank with the filler neck coming through the hood? do you have a tank and it's mounting bracket for your replacement engine? yes, you will need a different air cleaner and possibly different carburetor and throttle linkage....any close up pictures of them? you may also need to change the muffler.....pictures? 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,304 #8 Posted September 8, 2020 9 hours ago, mrtom said: This white engine was borrowed just to see how it fits. IMG_6763.MOV That lawn ranger appears to be in nice condition. What ever you do please don’t “hack” or modify that hood in anyway. There are other options with finding an engine that will fit. 4 1 Share this post Link to post Share on other sites
mrtom 15 #9 Posted September 8, 2020 I don’t know how that minibike video got in there, it was unintentional! Maybe i selected it by accident when uploading the tractor pic. If the moderator can delete that video please do so! i have the proper tank and mounting bracket so the filler goes through the hood. I have a small muffler that I can use with a short pipe nipple and a 45 elbow. Still thinking about throttle linkage etc. I promise not to hack up the hood! 😀 3 Share this post Link to post Share on other sites
SylvanLakeWH 31,769 #10 Posted September 8, 2020 5 minutes ago, mrtom said: I don’t know how that minibike video got in there, it was unintentional! Maybe i selected it by accident when uploading the tractor pic. If the moderator can delete that video please do so! i have the proper tank and mounting bracket so the filler goes through the hood. I have a small muffler that I can use with a short pipe nipple and a 45 elbow. Still thinking about throttle linkage etc. I promise not to hack up the hood! 😀 You can just go back to your post, click "edit" at the bottom, and delete the video. Then click save... 1 Share this post Link to post Share on other sites
mrtom 15 #11 Posted September 8, 2020 Done. Deleted video. Thank you. 2 Share this post Link to post Share on other sites
305 381 #12 Posted September 10, 2020 any updates on this? Share this post Link to post Share on other sites
mrtom 15 #13 Posted September 10, 2020 Done. Deleted video. Thank you. Share this post Link to post Share on other sites
mrtom 15 #14 Posted September 10, 2020 No updates yet. Will continue on this project next week. Need to make some money to support this habit! 😁 1 Share this post Link to post Share on other sites
mrtom 15 #15 Posted September 15, 2020 Today I mounted the H60 on the tractor. Everything positions as it should. I used a black pipe nipple and an elbow to mount a muffler. I still need to fabricate something for the throttle cable, and I’ll worry about an air cleaner as this project moves forward. I need to get a proper pulley for the 1” shaft. Not sure where to find it. The triple pulley in the picture is on another engine and impossible to remove. It has been hammered and set screw destroyed etc. d I need to get a pulley. Share this post Link to post Share on other sites
ebinmaine 79,739 #16 Posted September 15, 2020 Jump on your PC and do a little poking around online. There's a company called TB Woods that is sold by multiple sources. You could certainly put an ad in our wanted section. Mcmaster-carr. Grainger. Either one of them might have one. Share this post Link to post Share on other sites
ebinmaine 79,739 #17 Posted September 15, 2020 You know now that I think about it. PM or post all the measurements for me as best you can. I'll take a look and see what I have. Share this post Link to post Share on other sites
71_Bronco 1,072 #18 Posted September 15, 2020 I believe that pulley part number is 1621. Lincoln at A-Z Tractor has 4 in stock. https://a-ztractor.com/product/1621-u/ 2 Share this post Link to post Share on other sites
Tractorhead 9,217 #19 Posted September 15, 2020 to If you don‘t be able to find a pulley that fit‘s, you can also use at least a taper based 2 1/2“ Pulley with 3 rows. They be available with Taper socket for several diameters, but the better Way to go is the Way @71_Bronco allready mentioned. I don‘t have a lawn Ranger, but the gap between hood and Engine seems to be the same as on my 656. About the Airfilter, the H60 and HH60 are similar i have on mine a Kohler Filtercase, they seems to fit without any rework and be extreme Flat. Maybe anybody have one in spare and will sell it to you. 2 Share this post Link to post Share on other sites
mrtom 15 #20 Posted September 15, 2020 (edited) Ok, why does it need a three row pulley? One for the drive, one for the deck, and one for something else? You can tell I’m new at this 🙄. Maybe I need an owner’s manual. Is there a PDF online for that? Edited September 15, 2020 by mrtom Add comment. Share this post Link to post Share on other sites
mrtom 15 #21 Posted September 15, 2020 I just googled and downloaded a user manual. Good for part numbers anyway! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,371 #22 Posted September 15, 2020 Click on the picture Garry 1 Share this post Link to post Share on other sites
mrtom 15 #23 Posted September 15, 2020 Done and printed. Thank you! Share this post Link to post Share on other sites
305 381 #24 Posted September 17, 2020 on the three groove pulley i believe one is the drive , one for the mower deck and the last one for a snow blower? there is a three groove pulley that 71 bronco mentioned on that big online auction site right now for the same money as A to Z this is the air cleaner i have on my Lawn Ranger to clear the hood: Share this post Link to post Share on other sites
