Jeff Hennig 1 #1 Posted September 6, 2020 Does anybody know what WH models came with a horizontal Briggs, I know the GT2500 and the Work Horse 1100 do... I am looking for the plate, drive pulley (w/bearing) and the bearing plate. From what I can tell only the 11hp needed this setup, the 16hp Work Horse doesn't use it(?).. Thanks, Jeff Share this post Link to post Share on other sites
Bill D 2,321 #2 Posted September 6, 2020 Post an add in the wanted section of the classifieds. The bearing is available at Napa for around $6.00 bucks. Bill 1 Share this post Link to post Share on other sites
Jeff Hennig 1 #3 Posted September 6, 2020 Thanks Bill, still want to know what, if any, other models came with the 11hp Briggs.... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,604 #4 Posted September 6, 2020 Click on the fuzzy picture and scroll down to the 252400-Series of engines. The 8-speed models should be what you are looking for. 252400-Series including engine model 252417-0198-01 1979 C-111 8-Speed model 91-11B801 1980 1100 Special model 01-11B803 (8-Speed) 252400-Series including engine model 252417-0245-01 1981 GT-2500 model 01-11B804 (8-Speed) 1982 SB-371 3-Speed model 02-11BH01 1982 SB-421 8-Speed model 01-11BH01 252400-Series including engine model 252417-0259-01 1982 GT-1142 8-Speed model A1-114201 252400-Series including engine model 252417-0664-01 1983 GT-1142 8-Speed model A1-114202 1984 GT-1100 8-Speed model A1-11B801 Garry Share this post Link to post Share on other sites
Jeff Hennig 1 #5 Posted September 6, 2020 Thank you Garry!! 1 Share this post Link to post Share on other sites
Goldnboy 1,042 #6 Posted September 6, 2020 (edited) Jeff you can acquire the 1"drive pulley 101875, from a B60, B80, C82, or C85 and dremel out two of the notches on the back side to slip in the thrust bearing. The pulley you seek can be hard to come by. Edited September 6, 2020 by Goldnboy 1 Share this post Link to post Share on other sites
bds1984 1,503 #7 Posted September 6, 2020 The 16Hp Briggs will need the bearing plate unless the second to last character in the model number is a 3 or 4; that signifies ball bearings on the crank and I've seen both with and without. If you're in a bone yard and see a GT1600/GT1642 Work Horse, you may find what you are looking for there in addition to the models Garry listed. If your charging system is capable, what about going with an electric clutch? 1 Share this post Link to post Share on other sites
Jeff Hennig 1 #8 Posted September 6, 2020 Bds1984, thanks for the info, I thought the 16s might be stronger, but didn’t know there were ones with the plate. Share this post Link to post Share on other sites
bds1984 1,503 #9 Posted September 7, 2020 6 hours ago, Jeff Hennig said: Bds1984, thanks for the info, I thought the 16s might be stronger, but didn’t know there were ones with the plate. You're welcome, Jeff. If you are set on a Briggs, the majority of 18HP twins have ball bearings on the cranks; I've come across several on older Craftsman tractors from the 80s and early 90s. Those may be a source for an upgrade in power and still retain a traditional Wheel Horse clutch. Share this post Link to post Share on other sites
