Mikecetj 10 #1 Posted August 29, 2020 So, have a 1982 sk486, just got.... serial 01-16kh01-24458. Under that is 2054. It has the original (not butchered) rear discharge under belly mower. I am having a tough time deciding on blades, finding the tensioner pulley, and the belt for it.... any help? Pics for the fans 4 1 Share this post Link to post Share on other sites
ebinmaine 79,028 #3 Posted August 29, 2020 Nice looking horse! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #4 Posted August 29, 2020 Welcome to the forum. Can you read the mower ID plate? Garry 1 Share this post Link to post Share on other sites
Mikecetj 10 #5 Posted August 29, 2020 The tractor one, yes. The mower deck, no Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #6 Posted August 30, 2020 Just a guess. I can't tell the width of cut either. When I know what that is will give you a list of all the possibilities. Garry 2 Share this post Link to post Share on other sites
Mikecetj 10 #7 Posted August 30, 2020 I would have to say 36".... the deck total width is 40"... the blades are 2 x 12" and 1 x 14" 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #8 Posted August 30, 2020 Mower DNA 36" rear discharge 1972 model 5-0620 replaced by 1973-1974 model 5-0621 1975 model 5-0622 1976 model 65-36XR01 1977 model 75-36XR01 1977 model 75-36XR02 1978 model 85-36MR01 1979 model 95-36MR00 (Blades up to this point have the 5/8" x 3/4" double-D center hole unless the spindle has been upgraded) --------------------------------------------------------------------------------------------------------------------------------------------------------------------------- (These decks used blades with a 3/4" center hole) 1979 model 95-36MR01 replaced by 1980-1982 model 05-36MR01 - Last year for bearings with 3/4" ID 1983-84 model 05-36MR02 - First year for bearings with 17mm ID unless older spindles were updated. 1985 model 05-36MR03 1986-1990 model 05-36MR04 1991-1993 model 05-36MR05 1993-2006 model 78305 Note - 17mm is .669" Garry 1 Share this post Link to post Share on other sites
Mikecetj 10 #9 Posted October 18, 2020 It is the 05-36mr01. Got the blades and pulley right on the first try. The motor to deck belt is too long, and the deck belt is too long. Any ideas for part numbers? Share this post Link to post Share on other sites
peter lena 9,893 #10 Posted October 18, 2020 MIKECEtj, definitely that is a / 36 r/d deck , that blade actually looks not too bad , a small fine flat file will probably bring it right back ,with out removing too much metal , also scrap down the underside and lubricate it with waste oil , to kill off the grunge and stop rot. also soak down those blade nuts with penetrant oil. others will have those belt numbers Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,259 #11 Posted October 18, 2020 Drive belt 102741 (1/2" x 96.6") for B-Series & C-Series tractors with 45-1/2" wheelbase (Gates replacement BladeRunner 6638BR 17/32" x 96.75") Spindle belt 8411 (1/2" x 76.94") What belts did you get? Garry Share this post Link to post Share on other sites
bo dawg 638 #12 Posted October 19, 2020 Originally the SK486 would have came with a 48" deck. Should be what the 48 in the model number means 1 Share this post Link to post Share on other sites
