Mike e. 26 #1 Posted August 29, 2020 (edited) What is the electrical system on a C-175 6 or 12 volt? Edited August 29, 2020 by Mike e. Share this post Link to post Share on other sites
953 nut 69,556 #3 Posted August 29, 2020 12 volt negative ground electrical system. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,766 #4 Posted August 29, 2020 Far as I know every electric start Wheelhorse is 12 1 1 Share this post Link to post Share on other sites
Mike e. 26 #5 Posted September 10, 2020 (edited) Ok now I have officially started to work on my 81 C-175 it has the original kt 17 twin and it looks like I'm going to have to go through the whole wiring harness for the motor seeing where the wires for the coil and points have been redone but not right it looks like had a newer looks like a onan coil for a single cylinder engine so as it stands I need a proper wiring diagram and a coil and starter anyone knows where I can find these Edited September 10, 2020 by Mike e. Needed to put name of coil Share this post Link to post Share on other sites
pfrederi 21,182 #6 Posted September 10, 2020 10 hours ago, Mike e. said: Ok now I have officially started to work on my 81 C-175 it has the original kt 17 twin and it looks like I'm going to have to go through the whole wiring harness for the motor seeing where the wires for the coil and points have been redone but not right it looks like had a newer looks like a onan coil for a single cylinder engine so as it stands I need a proper wiring diagram and a coil and starter anyone knows where I can find these 1 Share this post Link to post Share on other sites
