TC10284 113 #1 Posted August 28, 2020 Got a 414-8 with a Kohler Magnum M14. Started it up today after a few months of not being used. Checked oil prior - had plenty of clean oil. Heard rattling/knocking sound from engine. I used it for a while to let it warm up good but it still did it. I'm pretty concerned something is loose inside the engine and is going to break or fall off soon. Is there anything I can do for it or does it require complete disassembly? Video: https://photos.app.goo.gl/AMmXVvSEF4riEdaq7 Share this post Link to post Share on other sites
Ed Kennell 44,911 #2 Posted August 28, 2020 Are you sure it is engine noise. I really couldn't tell from the video. I would take the belt guard and belt off to make sure that isn't the source of the noise. Then take the tins off and clean the cooling fins. This has to be done anyway to do a rebuild. You may get lucky and find the engine is OK. 2 Share this post Link to post Share on other sites
TC10284 113 #3 Posted August 28, 2020 (edited) I am pretty positive it is. I circled around it and it's the only place I can hear it from. Seemed to be loudest on the exhaust side, down near where there is a cover that I think covers the connecting rod linkage? Doesn't matter if I press in the clutch and it gets faster when I open the throttle. It doesn't smoke or anything. Concerned it is connecting rod linkage or something else coming loose. Edited August 29, 2020 by TC10284 Share this post Link to post Share on other sites
JAinVA 4,638 #4 Posted August 29, 2020 (edited) From your video I would suspect belt slapping the guard..I have 312-8 that makes the same noise.Belt guard is the issue on mine.Some times the sound gets louder when the clutch is pushed in if the pedal isn't pushed to the end of it's travel..Have someone push the clutch pedal down as far as it can go with he engine running and check to see if the belt at the engine pulley stops moving..If it is the belt slapping the guard you will know it. Edited August 29, 2020 by JAinVA Share this post Link to post Share on other sites
953 nut 64,142 #5 Posted August 29, 2020 11 hours ago, TC10284 said: Seemed to be loudest on the exhaust side, Could it be a baffle inside the muffler that came loose over the winter? 3 Share this post Link to post Share on other sites
oldlineman 1,653 #6 Posted August 29, 2020 My 1989 414-8 has a loose baffle in the muffler makes noise on and off for a long while, I just where ear protection while mowing. Your noise may not be this. Tap on the muffler while running and see if noise changes not to hard though! Share this post Link to post Share on other sites
Treepep 1,061 #7 Posted August 29, 2020 My GT-14 made a similar sound when the starter failed to disengage. May not be the sound that you are hearing but a new starer and I was back in business. Took me longer than I would like to admit to find it. Started fine. Noise increased with throttle. Thought for sure that the motor was failing. Come to find out the gear on the starter would hang on the flywheel just a bit after initial start. God awful racket. Best of luck to you. 1 Share this post Link to post Share on other sites
peter lena 9,770 #8 Posted August 29, 2020 tc 10284, i recently picked up a very trashed 3-14-8 , with a very similar noise issue, first off i agree with others on related possible noise from belt and guard area , also loose engine mounting . the " oil " in my engine was beyond lubrication life, got it started ,and ran at fast idle to heat it up , drained oil, fresh 30 wt , with rislone engine treatment , to flush out varnish and crud . ran 2 hrs , oil was black ,filthy , drained again , fresh oil and rislone engine treatment, started to sound better , idle was easier . i think the neglect and the wrong oil used in your engine is the issue. this is only my own experience, but the major thing i have found , is that recovery is slow , if you see a gain on noise and operation , it could be engine varnish and crud build up , got mine starting and running much better , before i sold it , my tractor was so bad , i was just not going to go through with it , separate you engine as much as you can to verify the issue, pete Share this post Link to post Share on other sites
clueless 3,348 #9 Posted August 29, 2020 The noise I hear is more of a rattle than a knock, and while it's consistent it is not nearly as consistent as a rod knock. Like the others, it sound more like something loose, belt guard, tins, give everything a good cleaning, then start checking nut and bolts. 2 Share this post Link to post Share on other sites
cafoose 3,595 #10 Posted August 29, 2020 Get yourself one of these, I have one and it's great for diagnosing noises Stethoscope 1 Share this post Link to post Share on other sites
Anglo Traction 761 #11 Posted August 29, 2020 (edited) If the rattle noise is coming from within the Crankcase, it will most likely be the Balance Gear bearings and/or shaft excessive wear. Not much else it can be inside. Have you tried to 'listen in' with a metal rod or tube (alternative to a stethoscope) in contact with the Crankcase whist engine running?. A very good method for isolating/locating trouble spots. If it is those gears, there's plenty of advice on here as to what to do with them!. Hope you find and cure it easily though. Regards EDIT - Cafoose beat me to it !. Edited August 29, 2020 by Anglo Traction 1 Share this post Link to post Share on other sites
stevasaurus 23,617 #12 Posted August 29, 2020 To me, it sounds like something rattling around just behind the tin around the flywheel...like a little stone or nut being kicked around. It doesn't sound like it is from inside the engine, more like a marble on the roulette wheel. Take off that particular engine tin and have something (like newspaper) under there to catch anything that falls out. One small piece of pea gravel under that screen. 3 Share this post Link to post Share on other sites
TC10284 113 #13 Posted August 29, 2020 (edited) It definitely sounds like it's in the engine. I took my mechanics stethoscope and listened to both sides. I heard most noise from the right side (exhaust) down near the base of the engine as shown in the pics below. I took one ear out to confirm I heard it at the same time as the stethoscope and I did. Same noise, just louder. https://photos.app.goo.gl/dRYSFgDncWcPg7VF7 Edited August 29, 2020 by TC10284 Share this post Link to post Share on other sites
clueless 3,348 #14 Posted August 29, 2020 Okay you got the belt guard off, now remove both belt from the PTO then run it, that will help with eliminating it being the PTO. 1 Share this post Link to post Share on other sites
Bill D 2,599 #15 Posted August 29, 2020 Check anything external first. Muffler baffles, PTO issues, debris in the flywheel such as nuts or seeds brought in by mice. Any debris in the starter that keep the gear partially engaged with the flywheel? Check for loose flywheel magnets. Is it charging properly? If everything else checks out my vote is for balance gears. Sounds a little like another video I heard on YouTube. Share this post Link to post Share on other sites
TC10284 113 #16 Posted August 29, 2020 Deck belt and drive belt removed. Noise still there: https://photos.app.goo.gl/VQnmEmntMfXEzYsG6 Yes, it is showing 14v on voltmeter. Share this post Link to post Share on other sites
johnnymag3 2,635 #17 Posted August 29, 2020 That is an awful erratic, non repetitive type noise... Leaning towards something loose in the tins....anything heavy metal sounding internally would be in the rotating mass....When was the last time the starter gear was serviced. That is a bigtime area that people fail to lubricate...and yes its in the manual for servicing regularly !!! Good luck, hope its an easy fix. Keep us posted Share this post Link to post Share on other sites
TC10284 113 #18 Posted August 30, 2020 I took off the flywheel shroud and didn't find anything obviously loose. The only thing I found was a dead mouse stuck to the fins of the block. Long dead. No way it was making that noise. I had to peel it off. That's all I've found so far. No dirt buildup, nothing loose. Everything has been very tight so far. 1 Share this post Link to post Share on other sites
oliver2-44 11,215 #19 Posted August 30, 2020 Since you have the flywheel tin off check the starter. Crank it over with the starter and see if the gear is engaging and disengaging properly. 1 Share this post Link to post Share on other sites
TC10284 113 #20 Posted August 30, 2020 The starter is engaging and disengaging properly. https://photos.app.goo.gl/Djj2zkPYGWPxLYZ19 What, internally, could this be? One person said balance gears - I saw that. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #21 Posted August 30, 2020 On 8/29/2020 at 11:34 AM, stevasaurus said: To me, it sounds like something rattling around just behind the tin around the flywheel...like a little stone or nut being kicked around. It doesn't sound like it is from inside the engine, more like a marble on the roulette wheel. Take off that particular engine tin and have something (like newspaper) under there to catch anything that falls out. One small piece of pea gravel under that screen. Share this post Link to post Share on other sites
The Tuul Crib 7,340 #22 Posted August 30, 2020 Balance gears or a big possibility but it could be a rod knockin. I also would suspect a timing issue. Share this post Link to post Share on other sites
953 nut 64,142 #23 Posted August 30, 2020 Could be the bearings in the PTO, does the sound change with the PTO lever moved forward? Share this post Link to post Share on other sites
TC10284 113 #24 Posted August 31, 2020 3 hours ago, 953 nut said: Could be the bearings in the PTO, does the sound change with the PTO lever moved forward? It didn't prior to disconnecting it all. Share this post Link to post Share on other sites
TC10284 113 #25 Posted September 1, 2020 On 8/30/2020 at 6:25 PM, The Tuul Crib said: Balance gears or a big possibility but it could be a rod knockin. I also would suspect a timing issue. Is there a guide to checking or adjusting the timing in the M14? Share this post Link to post Share on other sites
