305 380 #1 Posted August 27, 2020 i have a `68 Lawn Ranger that i have a 39" snow blade for. doing some comparing and measuring between that and my newly acquired `69 700 Workhorse i think it will go on....or am i nuts? anyone done it or know of any potential problems? thank you in advance 1 Share this post Link to post Share on other sites
ebinmaine 76,191 #2 Posted August 27, 2020 12 minutes ago, 305 said: or am i nuts? Probably. But that just makes it so you get along with us better. I don't know the answer specifically but I'm thinking if the width of the front axle is the same and the back will bolt on to the 700 okay, should work. 7 horse is more than enough to plow. The key is having enough weight to gain traction. Share this post Link to post Share on other sites
pfrederi 19,388 #3 Posted August 27, 2020 Lawn Ranger blades do not mount to the rear axle They have a pair of plates that mount where the mid mount tach matic would be. You would have to remove the drive pulley set up to mount the plates. I would think the frame holes would line up OK and the lift arm is in the same location... I have plowed with my L107 and she does a good job. i think that since you have to get on and off the tractor to reangle the blade I would put it on the Ranger. Much easier climbing on and off than the bigger tractor 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,888 #4 Posted August 27, 2020 Here is a list of the blades for your tractor in the order they were produced. 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle with a loose A-frame crossbar - replaced by 1969 model [6-4112 + 6-9621] 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 1980 model 06-42BC01 - (Last blade to have a loose A-frame crossbar #7701) 1981-1984 model 06-42BC02 (Up to here including this one they are 42" wide) and (First blade to have a welded-in rear A-frame crossbar) 1984-1989 model 06-48BC01 (They are now 48" wide) - replaced by the following 1990 model 06-48BC02 (Last blade to have 3 angle positions) 1991-1993 model 06-48BC03 (First blade to have 5 angle positions) 1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors 2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series) Garry Share this post Link to post Share on other sites
