peter lena 9,609 #1 Posted August 25, 2020 have this coming in , to ad to my lubrication arsenal , https://www.amazon.com/gp/product/B0059HJKQ4/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1 , much better access to long rusty areas. pete 3 Share this post Link to post Share on other sites
bottjernat1 2,196 #2 Posted August 25, 2020 I have one of those I have used many times on ball joins that dont have the grease erk. Very handy tool!! I bought mine when i bought my pistol grip grease gun 1 Share this post Link to post Share on other sites
Ed Kennell 43,946 #3 Posted August 25, 2020 I use mine to grease dry sealed bearings. 3 Share this post Link to post Share on other sites
peter lena 9,609 #4 Posted August 25, 2020 bottjernat1, i have been converting a number of bearings over to hi temp grease , lucas red n tacky, lucas heavy duty , high drop point 550 temp , bearing noise is gone and they work without effort , ED ,i figured that you would be on something like this , pete 1 Share this post Link to post Share on other sites
squonk 44,981 #5 Posted August 25, 2020 8 hours ago, peter lena said: have this coming in , to ad to my lubrication arsenal , https://www.amazon.com/gp/product/B0059HJKQ4/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1 , much better access to long rusty areas. pete I have one of those. About 40 years old. It's got a slight bend in it. 1 Share this post Link to post Share on other sites
peter lena 9,609 #6 Posted August 25, 2020 squonk, you know the general feed back i get from bearing issues is , that you can order bearings with a hi temp grease in them , its the combination of drag and resistance that also helps bearings to fail , since i have been detailing hi temp grease to bearing issues , the noise and failure rate is all but gone. i regularly zero in on a problem , no matter what , and make changes that make it just work better. the advantage of having an older style tractor , is that you are surrounded by used to be design, the issue keeps showing up , and i just like , tracking it down and making it work , like its not even there , making my horses work easily is a good time for me , pete 1 Share this post Link to post Share on other sites
squonk 44,981 #7 Posted August 25, 2020 I originally bought mine to grease my Snap-On air ratchet Share this post Link to post Share on other sites
