David414 323 #1 Posted August 24, 2020 I need some assistance please. Will a wheel horse 40 inch mid mount grader blade and lift link from a c-100 and 1045 wheel horse, fit a 1989, 414-8 wheel horse? Thanks, Share this post Link to post Share on other sites
David414 323 #2 Posted August 24, 2020 Need some assistance please. Does anyone know if a 40" grader blade used on a c-100 and 1045, will fit a 1989, 414-8 wheel horse? Thanks, 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #3 Posted August 24, 2020 Yes it will. Here is the order they were produced before they went to the pushed style 1965-1967 model MB-405 replaced by 1968 model 7-1111 1969-1974 model 7-1112 1974 model 7-1113 1975 model 7-1114 1976 model 67-40BM01 1977 model 77-40BM01 1978 model 87-40BM01 1979 model 97-40BM01 1980-1982 model 07-40BM01 Garry Share this post Link to post Share on other sites
ebinmaine 80,962 #4 Posted August 24, 2020 (edited) Yes sir. PINS right up. Edited August 24, 2020 by ebinmaine Minor repair of grammatical error on part of the writer Share this post Link to post Share on other sites
71_Bronco 1,073 #5 Posted August 24, 2020 9 minutes ago, ebinmaine said: Yes sir. Bolts right up. Well, technically there's no BOLTs, but we get the drift Share this post Link to post Share on other sites
ebinmaine 80,962 #6 Posted August 24, 2020 2 minutes ago, 71_Bronco said: Well, technically there's no BOLTs, but we get the drift Hahahahahaha I went back and fixed it up. Share this post Link to post Share on other sites
David414 323 #7 Posted August 24, 2020 1 hour ago, gwest_ca said: Yes it will. Here is the order they were produced before they went to the pushed style 1965-1967 model MB-405 replaced by 1968 model 7-1111 1969-1974 model 7-1112 1974 model 7-1113 1975 model 7-1114 1976 model 67-40BM01 1977 model 77-40BM01 1978 model 87-40BM01 1979 model 97-40BM01 1980-1982 model 07-40BM01 Garry Thanks for the info! What do you mean, before they went to the pushed style? Is there much difference between using a grader blade and the snow/dirt blade? Share this post Link to post Share on other sites
ebinmaine 80,962 #8 Posted August 24, 2020 1 minute ago, David414 said: Thanks for the info! What do you mean, before they went to the pushed style? Is there much difference between using a grader blade and the snow/dirt blade? David. The push style mounts to the back axle. It's a lot better used on a hydro tractor where you can control the lift a little easier. Trina has a grader blade on her 867. There's a couple videos on my YouTube channel that show her using it. The Mid Mount Grader is a drag style. The mount itself sits ahead of the blade. Share this post Link to post Share on other sites
JAinVA 4,638 #9 Posted August 24, 2020 (edited) That looks like the one I bought for my old c120.It should fit the 300/400 series.I had it on my 416h so you should be good to go.If you have not used one before they are quite handy.One word of caution is the lift handle can smack you on the knee on a manual trans if you hit a solid object Edited August 24, 2020 by JAinVA 2 Share this post Link to post Share on other sites
Pullstart 71,368 #10 Posted August 24, 2020 Yep, It’ll fit just fine! 1 1 Share this post Link to post Share on other sites
clueless 3,440 #11 Posted August 24, 2020 11 minutes ago, pullstart said: Yep, It’ll fit just fine! 2 Share this post Link to post Share on other sites
