71_Bronco 1,072 #1 Posted August 21, 2020 In the market for a new grease gun. In the past I've used the lever pump style with a rigid style tube. Was looking at the Lincon 1134, with the single-hand pump and the flexible style tube. I've also read good things about the Lock-N-Lube grease guns, but some people think the locking coupler is more of a gimmik than a feature. Not looking for a power or air version. Share this post Link to post Share on other sites
Stepney 2,356 #2 Posted August 21, 2020 I got fed up with every grease gun I owned inevitably leaking past the pressure ring and making a mess. I found an old brass Lukenheimer grease gun. Screw down type. No pressure remains on the grease when idle, and it never leaks.. Im not sure if they still make a gun like that. Share this post Link to post Share on other sites
ebinmaine 80,772 #3 Posted August 21, 2020 9 hours ago, Stepney said: Lukenheimer grease gun Hadn't heard of a screw type grease gun before. I've had 3 or 4 inexpensive but decent lever style guns over the years. ALL of them leak/leaked. I read where folks use a PVC tube with a capped bottom as a home made holder. Also an old tube sock as a fluid seepage catch. Share this post Link to post Share on other sites
Mikey the Monkey 701 #4 Posted August 21, 2020 DeWalt cordless are awesome. 1 Share this post Link to post Share on other sites
squonk 48,165 #5 Posted August 21, 2020 1 hour ago, Mikey the Monkey said: DeWalt cordless are awesome. I got an 18V with the Lock n Lube end. Works great! 1 Share this post Link to post Share on other sites
bottjernat1 2,197 #6 Posted August 21, 2020 Here is what i have been using for around 10 years now. It was a different brand name when i bought mine. same basic one tho. I love it. Share this post Link to post Share on other sites
tom2p 2,396 #7 Posted August 21, 2020 (edited) I must have a good grease gun because it works well and does not leak ... if it does leak might be a small amount because I don't notice it i will need to get a better look at it and check for identifying name or brand but I hate loading a grease gun because it's always a messy process prefer to use a fixed / rigid tube - but it can be a challenge (next to impossible) to reach the mower deck middle spindle grease fitting on a 300-500 series - so I use a gun with a flexible tube I like the small grease guns with the small cartridges - but they require too many refills for a Wheel Horse tractor that can consume a lot of grease ... especially the mower deck wheels I typically / primarily use Lucas Red n Tacky grease ... and also sometimes will use Bel Ray water proof / marine grease or Lucas water proof / marine grease Lucas Red n Tacky grease is good stuff Edited August 21, 2020 by tom2p Share this post Link to post Share on other sites
Stepney 2,356 #8 Posted August 21, 2020 4 hours ago, ebinmaine said: Hadn't heard of a screw type grease gun before. I've had 3 or 4 inexpensive but decent lever style guns over the years. ALL of them leak/leaked. I read where folks use a PVC tube with a capped bottom as a home made holder. Also an old tube sock as a fluid seepage catch. Borrowed pic off the net but mine is almost exactly like this. I only load up my Lincoln unit if I need to do a lot in one day. This seems to store better. 2 Share this post Link to post Share on other sites
C-85 822 #9 Posted August 21, 2020 I use a Milwaukee 12v grease gun, but I have an advantage, my son works for Milwaukee Tools as an mechanical engineer in their new products division. These things are awesome! With my old lever type guns it almost takes 3 hands to make them work, so this helps, one hand on the trigger and the other on the hose. I probably wouldn't have needed it for my W/Hs, but it's super handy for my big truck, that machine has a lot of fittings and can give me fits! C-85 5 1 Share this post Link to post Share on other sites
dodge78 146 #10 Posted September 4, 2020 I have found the best way to store a grease gun is with the hose hanging down. Gravity keeps the grease at the working end it leaks less 1 Share this post Link to post Share on other sites
gt14rider 1,278 #11 Posted September 5, 2020 Haven't found a leak less grease gun, but this accessory kit works well, 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #12 Posted September 5, 2020 On 8/21/2020 at 4:55 PM, C-85 said: I use a Milwaukee 12v grease gun, but I have an advantage, my son works for Milwaukee Tools as an mechanical engineer in their new products division. These things are awesome! With my old lever type guns it almost takes 3 hands to make them work, so this helps, one hand on the trigger and the other on the hose. I probably wouldn't have needed it for my W/Hs, but it's super handy for my big truck, that machine has a lot of fittings and can give me fits! C-85 We have three of these on my ship that we use to grease all the winches, life boat davits and fire flaps - what an awesome time and hassle saving device. The refill cartridges make that job relatively mess free and even the less adept of my crew mates has so far failed to break them - and some of those guys shouldn't be allowed to touch tools! Share this post Link to post Share on other sites
