mikemc53 10 #1 Posted August 16, 2020 I have been trying to find replacement blades for either or both of my tractors. I have a 1974 B-100 with 36" side discharge deck and a 1978 C-81 with a 36" rear discharge deck. I really only use the C-81 because the deck for the B-100 has been cannibalized and doesn't have much left. I did notice the blades are the same size but the B-100 has what appears to be high lift blades and the other does not. First, are they interchangeable? They sure seem to fit but not sure if there is a problem putting one in the other deck. Secondly, and most important, where can I get replacements? Nobody seems to have part numbers that cross reference these and both pairs of these are pretty beat and I could really use a new set or two. Thoughts? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,886 #2 Posted August 16, 2020 1974 36" side discharge model 5-0721 100776 14-1/8" center blade and 100777 12-1/8" left and right blades replaced by 101335 3-blade kit and no longer available from Toro (Hole 5/8in.x3/4in. Double-D) 2017 Oregon catalog part number 91-802 12-1/8" and Gator blade 96-632 12-1/8" still available. 101335 blade set available again from Toro June 4, 2019 1978 36" rear discharge model 85-36MR01 9187 center blade and 9188 left and right blades replaced by 8969 3-blade kit (Hole 5/8in.x3/4in. Double-D) 8969 blade set available again from Toro June 4, 2019 If your center hole sizes match. The deck could be newer or have had the spindles upgraded to use blades with a 3/4" round center hole. Garry Share this post Link to post Share on other sites
mikemc53 10 #3 Posted August 16, 2020 Thanks Garry! Share this post Link to post Share on other sites
