tallen4392 71 #1 Posted August 12, 2020 Anyone run 23 x10.50 x12 ag tires on the back of there charger 12 there looks like there is plenty of room someone near me has a set for sale .... Share this post Link to post Share on other sites
ebinmaine 79,711 #2 Posted August 12, 2020 I've done it on a 1267. Same tractor pretty much. They'll fit a B80 and C160 as well. You should be fine. Share this post Link to post Share on other sites
tallen4392 71 #3 Posted August 12, 2020 .... Thanks ..good to know before I go get them...... 1 Share this post Link to post Share on other sites
ebinmaine 79,711 #4 Posted August 12, 2020 4 minutes ago, tallen4392 said: .... Thanks ..good to know before I go get them...... Of course all us 5 year olds are gonna want pics. 1 Share this post Link to post Share on other sites
Roger R 473 #5 Posted August 15, 2020 They will work, but the seat pan will not open as far. To me the look is worth the difference 1 Share this post Link to post Share on other sites
tallen4392 71 #6 Posted August 15, 2020 That does look good ....Did you make the weight bracket setup on the front?? Share this post Link to post Share on other sites
tallen4392 71 #7 Posted August 15, 2020 I am looking for a way to put some weight on the rear without using wheel weights Share this post Link to post Share on other sites
rjg854 13,197 #8 Posted August 16, 2020 Use rimguard, windshield washer fluid or RV antifreeze to fill the tires, that will do what you want. Share this post Link to post Share on other sites
tallen4392 71 #9 Posted August 16, 2020 The rims have tubes in them right now I am looking for another set of wheels not having much luck Share this post Link to post Share on other sites
tallen4392 71 #10 Posted August 16, 2020 I have Rv antifreeze in my c81 works great I have been pushing snow with that for 5 or 6 years that little machine has never let me down Share this post Link to post Share on other sites
rjg854 13,197 #11 Posted August 16, 2020 So then, you already know what to do Share this post Link to post Share on other sites
Roger R 473 #12 Posted August 16, 2020 14 hours ago, tallen4392 said: That does look good ....Did you make the weight bracket setup on the front?? I did. The weights lift off like suitcase weights, and I can add more as necessary. As much for appearance as functional, steering traction was the main intent. Spraying the yard with a trailer sprayer, often on wet grass is one use of this one, (note the roller pump on the bottom of the frame) so quick response steering is important, along with pulling a 600# + roller. 1 Share this post Link to post Share on other sites
ebinmaine 79,711 #13 Posted August 21, 2020 On 8/15/2020 at 10:00 PM, tallen4392 said: looking for another set of wheels not having much luck Ever get upta Maine? I've a spare set or two. Maybe a good time to visit the meet n greet. Share this post Link to post Share on other sites
tallen4392 71 #14 Posted August 22, 2020 Thanks but that’s a haul 1 Share this post Link to post Share on other sites
ebinmaine 79,711 #15 Posted August 22, 2020 1 hour ago, tallen4392 said: Thanks but that’s a haul Oh I know.... I was born and raised around Athol. Share this post Link to post Share on other sites
